Sponsored by:
Sponsored by: CARiD
Loss of using 3.0 cams in the VQ35 swap
Old Oct 15, 2009 | 12:47 PM
krazy6's Avatar
I found a 95 maxima with a blown head gasket in my area for $800. I could probably pick it up for like $500.
I have been wanting to do this swap for awhile now. Want to make it pretty much a weekend/drag car. Car will be fully gutted and maybe even cut a little bit.
Mods would be:
3" intake with a velocity stack
Ebay VQ30 headers
3" exhaust with a magnaflow mufler dumped under the car
Block off plate
Wet kit with a .064 jet
Standalone fuel system for the kit
Summit star 15x8 with 235/60/15 MT drag radials (I have these already from my other car, might go to a 26x8.5 MT et drag)
Summit star 15x4 with 165/80/15 Nexens
My main question of this swap is how much power do you loose when you use the 3.0 cams and don't swap to the 3.5 cams? Pretty much the reason I want to do this, is so I don't have to use the cam spacers.
Thanks guys!
Old Oct 15, 2009 | 01:28 PM
Nealoc187's Avatar
SLOW
As far as I know I'm the only one who has done it this way, could be wrong though. No dyno numbers for me though so no way to really compare mine to others I guess. If I were to just venture a guess based upon the cam profiles I'd guess maybe like 10 or 15whp. Who knows though, I'm not a cam profile guru.
Old Oct 15, 2009 | 01:36 PM
krazy6's Avatar
Yeah, I saw your times and was gonna say that 104mph is pretty good with manifolds so it must not be that bad.
Just to make sure though, You don't need to run the cam adapters right?
Old Oct 15, 2009 | 01:46 PM
Nealoc187's Avatar
SLOW
Nope no adapters needed. You need to make sure the cam caps go back in the same spot they came off of, if you weren't aware of that.
Old Oct 15, 2009 | 01:49 PM
krazy6's Avatar
Alright cool, one less thing I have to worry about.
Thanks!
Old Oct 15, 2009 | 03:00 PM
Gemner's Avatar
You're stripping the car and making it a weekend race car, but you're going to go with using small cams and cheap out...why not take the time to do it right?
Old Oct 15, 2009 | 04:51 PM
krazy6's Avatar
I don't have any money. The cheaper the better. I'll spray 10hp more than lol.
Old Oct 15, 2009 | 06:15 PM
accordingtou's Avatar
VQ30 DE T
Good answer lol
Old Oct 15, 2009 | 06:51 PM
Gemner's Avatar
lol. spray 100 more
Old Oct 16, 2009 | 02:01 PM
505max94se's Avatar
You should definitely get some slicks with an .064 nitrous jet and a vq35.
Old Oct 16, 2009 | 02:16 PM
krazy6's Avatar
Originally Posted by accordingtou
Good answer lol
Yeah, probably gonna run some 26x8.5 slicks for the track and the 235/60/15s for the street.
Old Oct 16, 2009 | 02:31 PM
505max94se's Avatar
I was going to get some 26x8.5x15 slicks, but I ended up getting some 23x7.5x15 slicks due to the fact that I'll probably have to shift into 4th at the end of the track even with 26" slicks. I figured that if I have to shift into 4th, I might as well use it, so I went with shorter slicks. Plus a shorter slick will keep the front end lower which will help with weight transfer.
Good luck with the build!
Old Oct 18, 2009 | 02:54 PM
krazy6's Avatar
Sorry man, but you're gonna have a hard time hooking on those I think.
Old Oct 18, 2009 | 04:39 PM
kzoosho's Avatar
I ran 26x8.5x15's and i lit the the hell up the whole track lol. Plus will the smaller wheels fit your car without dropping it too much?
Old Oct 18, 2009 | 06:42 PM
t6378tp's Avatar
Turbo 3.5
This statement makes no sense, you can buy a broken car, slicks, headers, blockoff plate, motor, another fuel pump, fuel cell, fuel lines, afpr and etc. But you said I don't have any money.
cam adapters are not that expensive or if you do not want to use them drill out the 3.5 cams and use spacers
Old Oct 18, 2009 | 09:48 PM
Nealoc187's Avatar
SLOW
You guys saying he isn't going to be able to hook on those slicks seem to be forgetting that Jime uses that size and he pulled a 1.5 on them. There goes that theory.
Getting your tires to hook is much more about technique than tire size.
Old Oct 18, 2009 | 10:39 PM
MoncefA33's Avatar
I have 3.5 cams for sale for cheap, PM me if you're interested.
Old Oct 19, 2009 | 12:49 AM
505max94se's Avatar
That's exactly what I was thinking...
Old Oct 19, 2009 | 12:51 AM
505max94se's Avatar
Smaller wheels?
Old Oct 19, 2009 | 07:23 AM
kzoosho's Avatar
Smaller wheels?
So your are saying that the slick will not be any shorter than your stock setup?
Neal you also have to take into acount that Jim is an auto and has great control over his tranny. There isnt much room for user error there. Thats all i was saying by that.
Old Oct 19, 2009 | 09:03 AM
Blackwind's Avatar
neal can you explain this setup to me? im looking to 3.5 by jan and i think you may save me some extra work.
Old Oct 19, 2009 | 10:44 AM
505max94se's Avatar
No, the slicks are shorter than the stock tires, but not by too much. My stock tires are about 25.5" tall. The front of my car will sit about 1.25" lower with the 23" slicks. I thought you were talking about the wheels. My slicks are mounted to some 3rd gen se wheels.
Old Oct 19, 2009 | 12:48 PM
krazy6's Avatar
Basically anything I can save money on, I will.
I didn't know you could just drill the 3.5 cams. I thought to use the 3.5 cams you had to use the spacers and drill them. Damn, I'll just do that then.
He also has an auto, getting a manual to hook on that small of a tire is gonna be a lot harder.
Old Oct 19, 2009 | 01:39 PM
505max94se's Avatar
I'll find out soon enough.
Old Oct 19, 2009 | 04:08 PM
krazy6's Avatar
Hope it works for you man! Your car is badass.
TallTom
57
Oct 14, 2025 05:16 PM
mclasser
22
Nov 12, 2020 01:58 PM
wiseguy6199
Sep 29, 2015 05:00 AM
zmcneely13
Sep 26, 2015 02:26 PM
