Sponsored by:
Sponsored by: CARiD
ran into problems installing oovi, gurus please help my noob arse
Old Mar 17, 2010 | 02:26 PM
Ninos_Maxima's Avatar
be the change u want2C
ran into problems installing oovi, gurus please help my noob ****
ok so i had a oovi kit sitting in my basement for god knows how long and I thought it was complete. So i start stripping my 99max everything is going ok. I put on the new valve covers then notice that i only have half of the 00vi injector harness. I have 3 injector harness' now.
this is what im thinking, modify the 99 injector harness to fit the new injectors??
one other thing, i cant find the thread that tells you what to buy from home depot for the IACV adapter plate.
As always i appreciate any help, flames are welcome cause this is a noob problem!!!
Old Mar 17, 2010 | 02:30 PM
o great i just noticed its not a VAFC i have, its just a msd digital window switch PN 8969
Should i just go with the 4thgen lower, gonna break out the drill if you guys say so
Old Mar 17, 2010 | 02:58 PM
96nismoSE's Avatar
I had my 00vi drilled. It worked great and requires less of a tune. Well im just guessing it requires less since it already runs a bit rich stock so adding more air to the mix should (in theory) make the a/f ratio better.
Old Mar 17, 2010 | 03:48 PM
crap i lost one of the rubber o-rings for the lim that holds the injectors, gonna run to auto zone to buy some fuel line and im gonna try to find one of the o rings at home depot
Old Mar 17, 2010 | 04:30 PM
MaximaSpd85's Avatar
hmm lets see, i dont know how easy itll be to find clips, but if u find a way to modify urs let me know, cuz i have a friend in the same predicament, only 3 clips. you *may* be able to find some little connectors to put directly on the injector pins, but it would suck if they touched eachother, so idk about that. maybe solder them for the time being? once again, risky i think.
as far as the iacv, i dont think many people have tried to make their own plate out of home depot parts. i have seen one, but it looked like a bit of work. id just use the 5th gen iacv for now and if you must, then find an adaptor. i have zero issues from my 5th gen iacv.
Old Mar 17, 2010 | 05:56 PM
sorry i should have been more specific in my first thread. i have the triangular aluminum adapter plate, i dont know which parts to buy from home depot to put it on though.
i decided im just gonna drill the 00vi to fit the 4th gen lim. im gonna go buy 6 4th gen injectors tomorrow. god damn rubber o ring@@!!!@
Old Mar 17, 2010 | 07:59 PM
question, can i fill the 4th gen lim holes i dont need with jb weld, or do i have to go find some place to have them welded shut?
Old Mar 17, 2010 | 09:18 PM
hornepirate's Avatar
you should probably have them welded shut because jb weld can break off in the engine.
if anyone else has any other ideas as to how to fill the holes let me know because im in the process of doing my 00vi as well
Old Mar 17, 2010 | 09:34 PM
An idea i just had was to use loctite on a threaded rod cut to a certain length and allow time for it to seal
Old Mar 17, 2010 | 10:10 PM
^nice i was just thinking about getting an old bolt with locktite and dremmilling the top off, wow + 1 for hornypirate
so this is gonna be my set up
00vi
4th gen lower
00 iacv
4th gen fuel rail and injectors
00 throttle body and 00 tps. Gonna have to adjust it when i get the car running. My 99 one was crapping out
and im gonna remove my egr and block that suka off
cant really find good picks on how to make an egr block. any1 got any ideas? i dont want all that crud to get into my im
Old Mar 18, 2010 | 12:21 AM
schmellyfart's Avatar
I just cut the tube off right at the bottom portion of the guide tube and screwed a bolt into the chunk that was just cut off.
Heres a pic of the part that is not going on the car...I cant get a good pic of the blockoff on the car.
Old Mar 18, 2010 | 04:33 AM
96nismoSE's Avatar
i blocked of the egr using a quarter and jb weld. hasnt failed. lol. i sealed up my stock bolt holes with jb weld. worked great cause even if it does break its not going to go in the engine. its going to fall by where the knock sensors located which is harmless.
Old Mar 18, 2010 | 04:35 AM
00vi
4th gen lower
00 iacv
Im actually going to be going the same route as you. exactly. I'm working on blocking off the EGR as well. I haven't received the kit yet....I should have it by next Friday but i planned on removing the Guide tube all together
you have to leave the sensor hanging in the engine bay so no code will appear and Nissan sells a plug for the exhaust manifold I can't locate the part number. Also what could be done is to take a couple sheets of aluminum using an EGR gasket and bolt the aluminum with the gasket o the back of the manifold.
No ideas yet how to block off the exhaust manifold portion of the EGR
Old Mar 24, 2010 | 08:00 PM
im gonna use some bolts to block it off and dremmel them down.
I cant find any good pics on how to wire the 00vi and the RPM switch. can any1 help?
Old Mar 24, 2010 | 08:02 PM
and about the VIAS fix, is jb weld the best solution?
Old Mar 25, 2010 | 06:50 AM
MOHFpro90's Avatar
Have you checked my 00VI writeup? There are wiring diagrams for the RPM switch in there, as well as some of the other things you pointed out.
Old Mar 25, 2010 | 07:04 AM
VQ'ed's Avatar
I still have 10.8:1 AFR non-tuned between 5500 and 6500rpm after the VI transplant.
Old Mar 25, 2010 | 07:07 AM
VQ'ed's Avatar
[QUOTE=hornepirate;7473843
No ideas yet how to block off the exhaust manifold portion of the EGR[/QUOTE]
Buy the egr plug from the dealer on 2000-01 models. But be very sure that you use the right socket to remove the egr guide tube on the rear manifold, if not it'll strip (dont ask be how I know!!!lol) be sure the socket is very solid on the ''nut'' then unscrew with air tools.
Old Mar 25, 2010 | 09:38 AM
'question for vqed' do i really need air tools? i cant use a cheater bar?
This is how far i am so far.
I got the whole 4th gen im off. I got the new valve covers on, but i have to take them off again cause i forgot to run sealant round the gaskets, rofl.
I have not removed the VIAS system, or the EGR system yet. Those are the next things on the list to do. After that im drilling the the 00vi im to fit on the flipped 4thgen lim. Then im gonna start drilling wholes for the brake booster and then drill the little mini hole on the left side of the 00vi. I have titanium drill bits thanks to my dad so thats gonna cut thru this like a hot knife through buter.
he left me all of his tools, may god bless his soul.
-RIP dad 10/18/09
Old Mar 25, 2010 | 11:46 AM
VQ'ed's Avatar
Check this site:
http://tatanko.boredmder.com/
also, you can contact krismax, he's the father of the 00VI.
Old Mar 25, 2010 | 02:07 PM
ajcool2's Avatar
Krismax doesnt come on here any more.
Old Mar 25, 2010 | 02:08 PM
ajcool2's Avatar
-RIP dad 10/18/09
Good luck keep us updated. I love 00VI swaps.
sake1bs
Sep 19, 2015 09:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Balkins
Aug 12, 2015 06:39 AM
sc10692
Aug 9, 2015 09:37 AM
