Sponsored by:
Sponsored by: CARiD
Yet another 3.5 Swap thread (4th gen chasis, 2008 vq35)
Old Aug 23, 2010 | 10:54 PM
  #81
clickclock987's Avatar
cannot see the pics
Old Aug 25, 2010 | 10:54 AM
  #82
Remminator's Avatar
anyone else not seeing the pics, I see them fine.
Old Aug 25, 2010 | 12:50 PM
  #83
gt20ir's Avatar
I can see the pics just fine,
Damn that engine looks new!
Old Aug 26, 2010 | 03:15 PM
  #84
Remminator's Avatar
only 1400 miles, well about 1450 now!!!
Old Aug 26, 2010 | 03:58 PM
  #85
Blakfreestyle's Avatar
Question, did you buy adapters to use the vq30 timing on the 3.5? If so can you please post what this entails.
Old Aug 26, 2010 | 05:10 PM
  #86
gt20ir's Avatar
was this a maxima or altima engine? just curious.
Old Aug 27, 2010 | 08:49 AM
  #87
Remminator's Avatar
I believe it was a Maxima
Old Sep 10, 2010 | 12:18 PM
  #88
Remminator's Avatar
Can someone please help explain how/where to tap IM for 4th gen IACV?
Old Sep 12, 2010 | 10:15 PM
  #89
bamboomerang's Avatar
Figure out where you want the valve to sit in the bay then go from there, shorter/bigger the hoses the better, need to improvise. You drill/thread or weld a fitting on the plenum near the TB, at the VIAS (if you're blocked off) - I ran it through the UIM onto an adapted egr port blockoff on my 00vi and it worked fine. Ideally, you could have a threaded fitting going into the IACV blockoff threaded directly into the UIM, bypassing an IACV->plenum hose altogether so it's not actually a 'remote' mount.
Old Dec 11, 2010 | 12:27 PM
  #90
shift_5's Avatar
Am I overlooking something? Shouldn't the 4th gen FPR be on the other side and going to the return? If you keep the 5th gen damper on the feed side and put the 4th gen FPR on the other side the fuel rail will always maintain the factory pressure and you won't have to mess with that ebay crap. The factory nissan fuel regulators are designed to be at the end of a fuel rail to maintain a certain pressure and release any extra fuel back to the tank, right?
Old Jan 7, 2011 | 01:54 PM
  #91
Remminator's Avatar
you are correct, I had the fpr on the feed side instead of the return side.
Old Feb 3, 2011 | 01:54 PM
  #92
KRRZ350's Avatar
Looking good, smart choice on swapping the pans, you would have had a big gaping hole behind your flywheel afterwards & a cps that sits in a ****ty spot. Did you remove the '08's baffle from the main girdle or remove the 3.0's from the pan?
Old Feb 7, 2011 | 04:33 AM
  #93
Remminator's Avatar
Smile
Yeh, I was completely thrown when I first saw that spanking new motor with the big chunk missing from the pan. I elected to go with the 3.0 pans. I thought it was a no-brainer considering the matching hole patters and sensor mounting. Now my act clutch is safely contained instead of being exposed to the elements.
removed the 3.0 from the pan.
6000 on this swap now, my daily driver.
Old Feb 10, 2011 | 06:34 AM
  #94
ClutchClownnn's Avatar
thumbs up to the six pluck clutch
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Blackwind
Aug 5, 2015 06:35 PM
