Sponsored by:
Sponsored by: CARiD
Has anyone ran their AFR at 13.5:1 all across without pinging?
Old Apr 16, 2010 | 07:54 PM
shadyonedeath's Avatar
Wondering if its even necessary on a DE-K N/A. Currently im running 12:1 passing 5800 just because someone told me when i was starting out tuning. I can definitely tell it pulls harder at 13.5:1 than 12:1 (in the higher RPM's).
Thoughts?
Old Apr 17, 2010 | 01:27 AM
MoncefA33's Avatar
13.5 is a little high IMO. Tune for high 12s-13.2 AFR so the combustion temps stay cooler and reduce pinging. My car is running like 12.6 AFR currently.
Old Apr 17, 2010 | 01:50 AM
Gemner's Avatar
what are you tuning with? if you can advance timing, you will likely find more power by advancing the timing and running more like 13.0:1 than running at 13.5:1
Old Apr 17, 2010 | 07:16 AM
NmexMAX's Avatar
dot dot dot ...
I've done 13.8-14.0 w/ my VQ35, no issues even in the summer (95 degrees)
Old Apr 17, 2010 | 08:34 AM
Kevlo911's Avatar
Kevlo for President
Yes, I have done 13.5 in the FL heat w/o problems
Old Apr 17, 2010 | 09:22 AM
VQ'ed's Avatar
actually running 13.2:1 from 4000rpm to 6600rpm. Before, it was at 11.0 or so. The car pulls harder than before for sure. tuned with AEM wideband and V-afc2.
Old Apr 17, 2010 | 12:10 PM
VQ'ed, your saying it pulls better with 13.2 than 11 at the high end?
tuned with LC-1 and vafc2. Not the best, especially if street tuning.
Old Apr 17, 2010 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
One of the highest NA DE/MEVI'd dynos comes from 14.0. You have ti go dyno and see what works best for your set-up ... I thought this has been established?
As a general rule, we look for 12.5-14. See what works best, and also, rul of thumb for our engines = flat line typically works well.
Jime uses 12.5 IIRC and he's really fast/powerful.
But, in order to prove to yourself, see what's best for you.
Old Apr 19, 2010 | 08:32 AM
Aaron92SE's Avatar
NWP Engineering.com
I try to stick around 12.8-13.0. With the timing the same, I see no difference in power by leaning it out to 13.5. And I also see no difference in power by going as rich as 12.5.
I accidentally used the wrong map once and I made a pass down the 1/4 mile with 15.2:1 AFR and the timing around 26 degrees without any knocking registered at all. The car was about 3 tenths slower, but it was fine. This is with my naturally aspirated VQ35DE making 290whp.
fastcarny
Oct 6, 2015 10:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
msellas
Sep 23, 2015 09:16 PM
