Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Apr 26, 2010 | 06:18 AM
  #81
Deckdout2's Avatar
Play with my balls
Originally Posted by cmax1
How come you cant start the engine without the calipers?
Because of the method I'm using to break in the motor. After the initial start up of the motor, I will not be turning the car off until it is broken in, so it requires me to drive it. Which is why I need brakes.
Old Apr 26, 2010 | 10:37 AM
  #82
TB.4L's Avatar
Keep up the good work.
Old Apr 26, 2010 | 11:03 AM
  #83
essential1's Avatar
My axles cry for mercy...
What method is that your using. Curious.
Old Apr 26, 2010 | 01:41 PM
  #84
Deckdout2's Avatar
Play with my balls
Source:
http://www.mototuneusa.com/break_in_secrets.htm
I'm using the Dyno Breakin Method on the street. Probably with 2nd and/or 3rd gear to stay as close as I can to the speed limit.
Do Three 1/2 Throttle runs from
40% - 60% of your engine's max rpm
Let it Cool Down For About 15 Minutes
Do Three 3/4 Throttle runs from
40% - 80% of your engine's max rpm
Do Three Full Throttle runs from
30% - 100% of your engine's max rpm
When coming off the Throttle in each step, you should let the engine brake the car vs using the brakes to slow you down.
Change the Oil, and drive!
Old Apr 26, 2010 | 03:22 PM
  #85
streetzlegend's Avatar
Source:
This was one of the most confusing part of my build, knowing what is the best way to break it in. I went with the same method, drive it how it was built to be drive with alot of engine braking.
Old Apr 27, 2010 | 06:06 AM
  #86
zero2sixtyZ's Avatar
You embarrass me.
Very impressed with your build. Always loved your car, and this is the icing on the cake. Can't wait to see some numbers and videos. Good luck man!
Old Apr 27, 2010 | 11:58 AM
  #87
deezo's Avatar
Originally Posted by NmexMAX
LOL! Let's see what Pinky comes up with.
Old Apr 27, 2010 | 05:18 PM
  #88
MaximusTi's Avatar
Awesome build ! I just picked up my 5.5 and I'm just doing the basic bolt on stuff. I am curious to see the end results (Time Slips, Area under the curve) because I have very similar goals. Congratulations !
Old Apr 27, 2010 | 08:56 PM
  #89
Deckdout2's Avatar
Play with my balls
She's Alive!
Old Apr 27, 2010 | 09:13 PM
  #90
SR20DEN's Avatar
VQ Wizard
Old Apr 28, 2010 | 05:53 AM
  #91
Deckdout2's Avatar
Play with my balls
Untuned
4 Pulls
2nd Gear Pull
100% Throttle
1950rpms - 6500rpms
Old Apr 28, 2010 | 06:34 AM
  #92
Blackwind's Avatar
man that looks like fun!! whats that scraping sound?
Old Apr 28, 2010 | 06:50 AM
  #93
Deckdout2's Avatar
Play with my balls
That would be my 275 tires in the rear. I've been rolling the fenders the past 2 days, but I guess I need to work on it some more. I hope to get rid of that soon.
Old Apr 28, 2010 | 06:52 AM
  #94
Blackwind's Avatar
oh, well either way that thing sounds crazy. good work, you just gave me the road i want to take when i finally get mine done.
Old Apr 28, 2010 | 07:09 AM
  #95
Deckdout2's Avatar
Play with my balls
Thank you! I hope to get better vids soon of everything. I was just anxious to get her started last night and running, so this is the 1st Vid.
Old Apr 28, 2010 | 07:52 AM
  #96
SR20DEN's Avatar
VQ Wizard
Untuned
4 Pulls
3rd Gear Pull
100% Throttle
1950rpms - 6500rpms
It was second gear, not third. Remember? I did not want to get caught doing 90+mph on 521, so I didn't use third gear for the 100% RPM stage of the break-in.
Old Apr 28, 2010 | 07:54 AM
  #97
Deckdout2's Avatar
Play with my balls
I'm an idiot, thanks for clarifying. Why did I think it was turd gear?
Fixed.
Old Apr 28, 2010 | 12:19 PM
  #98
Blu's Avatar
Blu
the tits
Drive it to football tonight, I want to see it. Should be pretty nasty once you throw some timing at it.
Old Apr 28, 2010 | 12:43 PM
  #99
Deckdout2's Avatar
Play with my balls
I wish. I still have some house cleaning to do on it before she goes anywhere.
Old Apr 28, 2010 | 01:31 PM
  #100
You embarrass me.
six to midnight.
Old Apr 28, 2010 | 04:37 PM
  #101
Phantom-V's Avatar
i so want to see some dyno runs to see how worth it it is to build our maxima VQ35DE motors. This project has already started for me...but i want to see if i should stop or continue buying parts.
like, can you really feel the difference now compared to modding like a 240 or something?
Old Apr 28, 2010 | 06:12 PM
  #102
Deckdout2's Avatar
Play with my balls
There is definitely a big difference in performance. How much? Unknown until she is tuned and placed on the dyno. Compared to a 240 or the like? Don't know, I've never modded one or been in one that has been before or after. I don't have a comparison for you, but I will have results once everything is completed and measured.
I "should" have a baseline dyno soon which will only be a base air/fuel tune so that I can at least drive her around with steady idle and a flat 13.5 a/f without worrying about it dying on me at every light. After the 1500miles, then I will tune the hell out of it while adding the bigger MAF, 380cc injectors, extended rev limiter, and much more timing. Then we'll see how much of a difference and how true this build will shine.
Stay tuned, she's still having minor things buttoned up to make her a daily driver.
Old Apr 28, 2010 | 06:46 PM
  #103
Deckdout2's Avatar
Play with my balls
Originally Posted by zero2sixtyZ
six to midnight.
LOL. Just figured out what this meant after now watching, Forgetting Sarah Marshall.
Old Apr 28, 2010 | 06:59 PM
  #104
03BlkSETE's Avatar
Car sounds great in the vids.
How do the cams sound at idle or is it stalling out at idle?
Old Apr 28, 2010 | 08:39 PM
  #105
Deckdout2's Avatar
Play with my balls
Thanks man.
From the engine compartment, I want to say that the motor sounds pretty close to stock. She does idle, when I play with the accelerator a little to get to that catch point. When that happens, the cam's loop can be heard via the 3" exhaust which really sounds good. With this motor the exhaust has a much deeper bass now in turn making it louder as the bass resonates. I'll have to get an idle sound clip soon. Might do this during the a/f tune at the dyno.
Old Apr 29, 2010 | 05:50 AM
  #106
tuko316's Avatar
Do you know what the a/f ration is now? How's the low end? Is there any traction with the hlsd or does it spin like crazy with all that power?
Old Apr 29, 2010 | 06:38 AM
  #107
Deckdout2's Avatar
Play with my balls
My wideband is hooked up and ready to go, but the o2 needs a bung welded in the y-pipe. I won't know what the a/f is until that happens, which I will tune at least the a/f at that time to 13.5 flatline. HLSD helps more with cornering and slip, but I only hit it once in 1st gear that night, and it was basically non existent. Lowend is a pig without a tune at the moment, but will be fixed. I'm also running the Fidanza flywheel and a shorter FD gear.
Old Apr 29, 2010 | 07:28 AM
  #108
Phantom-V's Avatar
I am tuned in man. Can't wait to see those numbers. Awesome build !!!
Old Apr 29, 2010 | 10:34 AM
  #109
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Even with a tune you dont stand a chance.
Old Apr 29, 2010 | 10:45 AM
  #110
aznstormin's Avatar
like the picture
Old Apr 29, 2010 | 11:25 AM
  #111
Rods03Max619's Avatar
Damn looks real good and is that a Passport Radar for like 500 bucks if so or tell me the brand and how is that working out for you?
Old Apr 29, 2010 | 01:51 PM
  #112
Deckdout2's Avatar
Play with my balls
Haytor.
Old Apr 29, 2010 | 01:53 PM
  #113
Deckdout2's Avatar
Play with my balls
It is.
It's the 9500ix with GPS. It's the sickest one I have owned. I'm Escort loyal, and have had 3 models in the past. Got this one for my birthday last year, and absolutely love it. Lives up to all the hype and the price as well.
Old Apr 29, 2010 | 04:41 PM
  #114
MaximusMorpheus's Avatar
Congrats Deckdout2 on firing the beast up and the first video is nice! Moar vids!
How does it compare from before the build in terms of pulling from 2nd gear? Butt dyno?
Can't wait to see some great dyno numbers for the best 5.5 N/A build to date!!
Old Apr 30, 2010 | 05:44 AM
  #115
Deckdout2's Avatar
Play with my balls
It's hard to tell since for 1, I haven't driven her in 5 months, and second she's untuned at the moment, so she's still jumpy before 5k at full throttle. After 5k she opens wide for me.
Sorry I don't have much to give you guys at the moment until I get it tuned. I will have more of a results post after that occurs.
Old Apr 30, 2010 | 01:42 PM
  #116
vastmax's Avatar
I have yet to post in this thread, better late than never.
I'll be honest...even without a tune this car is nasty. Once it gets out of the bottom end, the thing just screams (as you can see by the vid).
Good job and congrats again P, cant wait to do the photo shoot...these guys have no idea.
Old Apr 30, 2010 | 07:40 PM
  #117
e-subliminal-2's Avatar
We sure don't. All this waiting better be worth it!
Old May 3, 2010 | 11:07 AM
  #118
Puppetmaster's Avatar
You can get 5 cars from a 140 roll and I will still take you....
Old May 5, 2010 | 07:58 AM
  #119
mattbaga's Avatar
so hott...want to touch the heinyy
Old May 5, 2010 | 04:57 PM
  #120
DandyMax's Avatar
3.5 in the works
Very nice! Good to see some serious builds starting. Looking forward to dyno #'s (and track times??)
Who did your heads?
