Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Apr 19, 2010 | 08:36 AM
Deckdout2's Avatar
Play with my balls
I guess the time has come for me to post this thread. The only thing I'm waiting on at the moment is for the new Wilwood calipers to come in so I have some brakes to stop this thing. Will start her up for the first time with the new motor as soon as that happens this week or early next week. I was hoping to start her this past Thursday, but the brake bleeding issue prevented that from happening.
I built this motor in my garage along with major assistance from SR20DEN (Matt - The VQ Wizard) since January. Should have been done in February, but got held up at the machine shop who was hand porting my heads.
The only thing left out of the equation on initial startup is the Deatschwerks 380cc Injectors, 3" Maf, and Utec Tuning. Will start it up and break-in the motor with the stock ecu and run her for about 1500 miles initially. I will then go to the dyno and tune her and add the above items. Will probably be dynoing the 350z/G Revup and Non-Revup manifold during this time as well to see what gains could be had.
There will be a few videos in different stages that I'll be posting up, so stay tuned in this thread. I have a stash of photos through this 5 month build so just ask if you'd like to see anything in particular.
So my goal for this build is to push as much power as I can out of the stock block, Naturally Aspirated. No rules involved here except for using a VQ35DE stock block (same one that comes in the car) and no Forced Induction....ie, Supercharger, Turbo, or Nitrous. If I break 300+ whp All Motor, I'll be a happy camper. On to the goodies.......
Wiseco 11.0:1 CR Pistons (.020 over stock)
Eagle Rods w/ARP Rod Bolts
Brian Crower 264/264 Cams
VQ35HR Valvesprings and Retainers
Double Shimmed Valvespring Seats
5 Angle Serdi Valvejob
Ported and Polished Heads
Heads Decked
Fully Blueprint and Balance
Polished and Balanced Crank Independently
Balance as Rotating Assembly to 10k RPMS
OEM Main Crank Bearings
ACL Race Rod Bearings
HR Headbolts
HR Headgaskets
Samco Hoses
UTEC w/Map Selector
TurboXS Tuner Wideband
Defi-Link Controller II
Defi BF White Imperial Water Temp Gauge
Defi BF White Imperial Oil Temp Gauge
Defi BF White Imperial Oil Pressure Gauge
2 Step WOT Launch Control/No Lift Shift Module
Walboro 190lph Fuel Pump
Extended Rev Limiter to 8k RPM's
Ralco RZ Lightweight Crank Pulley (Standard Size)
SPEC Stage II Clutch
Fidanza Lightweight Flywheel
NGK 1 Step Colder Plugs
HKS DLI II Twin Power Ignition
3" MAF Housing
Ported Upper Intake Manifold
Port matched Upper and Lower Intake Manifold
NWP Manifold Spacers
Cattman Gen 3 Headers
Cattman Fastcat
Cattman 3" Catback Exhaust
350z Thermostat in Maxima Housing
Koyo Radiator
VQ35DE Revup Oil Pump
6th Gen Maxima 6-speed Transmission HLSD
4.133 Final Drive Gear Ratio
Greddy Oil Filter Sensor Adapter
HKS Oil Filler Cap
HKS Radiator Cap 1.1Bar (Stock 0.9Bar)
Energy Suspension Poly Urethane Motor Mounts
Energy Suspension Poly Urethane Control Arm Bushings
Energy Suspension Poly Urethane Shifter Bushings
Energy Suspension Poly Urethane Sway Bar Bushings
Ported - Painted - Portmatched Intake Manifold
Eagle Rods
Wiseco 11:1 Forged Pistons
Old Apr 19, 2010 | 08:40 AM
tonedef's Avatar
keep us posted!
Old Apr 19, 2010 | 08:41 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 08:43 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 08:45 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 08:47 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 08:56 AM
sal210's Avatar
wow, this is absolutely amazing. i cant wait to hear the numbers. great job my man.
Old Apr 19, 2010 | 09:04 AM
Crusher103's Avatar
This thing should be pretty nasty, im in for dyno #
Old Apr 19, 2010 | 09:07 AM
Crusher103's Avatar
i would have like to see some more aggressive cams thou, some 272s or 280s, that would have made for an interesting idle.
Old Apr 19, 2010 | 09:17 AM
perkman87's Avatar
300 should not be a problem'.
Old Apr 19, 2010 | 09:23 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 09:24 AM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 09:32 AM
Deckdout2's Avatar
Play with my balls
Thanks guys! It's been alot of work, and time away from the girlfriend. Just can't wait for it to be done.
I don't remember why, but there was a good reason I didn't go that big. It will come to me, but my midrange on up should be very nice and linear. We'll see what the dyno says.
That's what they say, but it's never happened before, in a Maxima as far as I can recall.
Old Apr 19, 2010 | 10:32 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
That oil cap better make some mad tyte JDM powwwaaaa. Going to be stout for sure.
Old Apr 19, 2010 | 10:34 AM
SR20DEN's Avatar
VQ Wizard
You still can't get revenge on the 2001 Sloppymax autotragic.
Old Apr 19, 2010 | 10:38 AM
sloppymax's Avatar
3.0liter4lyfe
Old Apr 19, 2010 | 10:40 AM
Blu's Avatar
Blu
the tits
Wut makes it so fast?
Old Apr 19, 2010 | 10:41 AM
DrunkieTheBear's Avatar
Turbo'd Saab
This should make nice numbers. Good job
Old Apr 19, 2010 | 11:21 AM
krazy6's Avatar
Looks like a pretty solid build. I think you should go with some bigger cams though. 0.426" lift is pretty weak. I think you should get some custom ground cams with around 0.500" lift. You'll make some serious power then.
Old Apr 19, 2010 | 11:47 AM
NmexMAX's Avatar
dot dot dot ...
Not to make this a cam discussion thread, but the cam angle should be looked at as both a ramp & peak lift vs just a peak value. So, the second derivative applies (A change within a change re: cam angle, vs a huge spike/lift ... )
Anyhow.
oohh!!111 j00 hAs a motAr now!
Old Apr 19, 2010 | 12:22 PM
burnurass's Avatar
Looks GOOD! Hopefully you got some sticky tires for all this newfound power.
Old Apr 19, 2010 | 12:40 PM
NISSANMAXIMA91's Avatar
guh! I need a new pair of pants...
But seriously...that thing is going to be BAD A$$
Old Apr 19, 2010 | 12:42 PM
Rhyno02's Avatar
...drool. Uber jealous. Nice work. Side note, interested to see how the intake manifold looks installed and painted bc I was thinking about doubt that too.
Old Apr 19, 2010 | 01:24 PM
tuko316's Avatar
Congrats. Should turn 300+whp. There was a 350z with the same cams and 315whp.
Old Apr 19, 2010 | 02:12 PM
mist max2000's Avatar
amazing.. how much chaching you got into her so far?
Old Apr 19, 2010 | 02:13 PM
jkpgt96's Avatar
Looking forward to seeing the numbers on this! The lift only matters so much on a multi-valve motor anyways, the duration is what is going to make it pull like a raped ape upstairs..
Old Apr 19, 2010 | 02:27 PM
LongIslandMax's Avatar
In for dyno #'s. Will this beast be at Maxus?
Old Apr 19, 2010 | 02:57 PM
essential1's Avatar
My axles cry for mercy...
4th gen engine bay, but you can kinda get an idea. I'm lookin forward to this build too.
Old Apr 19, 2010 | 04:28 PM
shift_123456R's Avatar
why only 11.0 compression?
Old Apr 19, 2010 | 04:37 PM
02max245's Avatar
Looks sweet!
Old Apr 19, 2010 | 04:42 PM
Deckdout2's Avatar
Play with my balls
Thanks guys! I'm siked about getting her started up.
I just wanted to stay below 12.0:1 so I can have the street ability of using pump gas as well without any detonation problems and having to run race gas the whole time to solve it. With the headgaskets, milled deck heads, and block I should be able to yield closer to 11.3:1 or 11.5:1. We'll see what the final CR is soon.
Old Apr 19, 2010 | 04:45 PM
Deckdout2's Avatar
Play with my balls
Moar Pics!
Tranny Mounted
Success!!
Old Apr 19, 2010 | 04:49 PM
Deckdout2's Avatar
Play with my balls
Finally!
Fluids filled and all buttoned up. Just need to add the airbox, battery, and Front Calipers.
Dear Wilwoods,
Hurry up!
-Paramy
Old Apr 19, 2010 | 04:51 PM
Deckdout2's Avatar
Play with my balls
Old Apr 19, 2010 | 04:53 PM
jkpgt96's Avatar
At 12:1 I am always going to run premium and we are pulling a lot of timing out of the tune to run on pump gas, but I won't be running pump gas all that often, only when I am just leisurely cruising around in the Probe..so..it can be done, but I agree it is/will be a pain!
Ever think of having custom longtubes made?
Old Apr 19, 2010 | 04:57 PM
03BlkSETE's Avatar
Awesome Deckdout! Can't wait to hear her, and see some dyno's. So SR20DEN is still involved with Maximas huh?
Old Apr 19, 2010 | 05:04 PM
Deckdout2's Avatar
Play with my balls
50/50 at the moment. Just gotta see how my schedule goes around that time. Would love to make it to my 1st ever Maxus though.
The huge *****.
That's ok, he now has something faster that I'd like to have a go at.
Honestly......I'm afraid to add it all up. I could have probably gone FI with a 1/3 built motor I'm sure.
Old Apr 19, 2010 | 05:06 PM
Deckdout2's Avatar
Play with my balls
I'd like to go a little heavy on the timing as well now that I have forged pistons. She's always had 93 or better since I've had her, but I'm anxious to see what she will do with a 100+ octane tune. Luckily, I can set a map for that too.
Old Apr 19, 2010 | 05:07 PM
Deckdout2's Avatar
Play with my balls
What's the significant other say about this, Matt? lol
Old Apr 19, 2010 | 05:08 PM
nismomaxct's Avatar
Gorgeous build. Glad to see everything is coming together and almost finished.
