Sponsored by:
Sponsored by: CARiD
Glowing Header
Old Jul 27, 2010 | 09:46 PM
jagshark89's Avatar
Glowing Header
Since 3.5 swap into 4th gen maxima with 5spd swap. I have a glowing header on only one bank, the bank nearest the firewall, Its glowing a bright orange not long after running the engine at idle maybe 3-4 minutes. I'm afraid to drive the car for fear of doing permanent damage to the internals of the motor. The header near the radiator are normal. In the morning im going to pull the plugs to check them and get an idea of whether or not i am running rich or lean. I wanted to know if any of you guys had any other ideas.
Old Jul 27, 2010 | 10:51 PM
shrek's Avatar
i think that you are getting high EGTs sometimes caused by a lean mixture but
does the front side headers gets glowy(maybe a little) or is it ok???
it coud be that the one on the rear dos not get ventilation
Old Jul 27, 2010 | 11:02 PM
jagshark89's Avatar
the front header is completely normal not even a hint of glowing. I did want to add in that the idle is a little rough and i am running emanage ultimate. I'm not sure if this problem is related to tuning but i would assume that would affect both headers and not just the back one.
Old Jul 27, 2010 | 11:13 PM
Crusher103's Avatar
thats odd but are u sure its not just the rear header, the front one is probably in teh same condition its just more light hits it. have u tried looking at it at night? just to make sure.
Old Jul 28, 2010 | 12:16 AM
DrunkieTheBear's Avatar
Turbo'd Saab
emanage ultimate allows you to control each combustion chamber, so your tune could have affected the rear bank
Old Jul 28, 2010 | 12:34 AM
jagshark89's Avatar
im sure that its just the rear header ive looked at it in both day and night. The emanage hasnt been tuned yet i just have the basic setup running on it. I havent adjusted any of the fuel maps on it.
Old Jul 28, 2010 | 08:24 AM
gt20ir's Avatar
If its glowing at idle that fast, then It could be a few things,...
Very Lean,
Very retarded ignition timing
Cam timing is off...
I have seen a few instances where overly rich was causing it to glow because the fuel would condense to the head pipe and then it would burn after the exhaust valve closes and fresh air travels back up the pipe, but only maybe once or twice.
Old Jul 28, 2010 | 08:26 AM
Crusher103's Avatar
i would pray im just running very lean.
Old Jul 28, 2010 | 09:29 AM
NmexMAX's Avatar
dot dot dot ...
Just an FYI, EGT's actually drop after stoich is met (14.7:1). EGT's are highest @ 14.7:1, and drop on either end of that.
Wideband readout/data?
We all idle @ 14.7:1 (most of us) and that's the theoretical highest EGT. And none of us have glowing manifolds or headers. Weird.
What type of headers are they?
Old Jul 28, 2010 | 11:07 AM
Nealoc187's Avatar
SLOW
it's glowing at IDLE? holy crap.
cam timing off (meaning exhaust valves are opening early) or exhaust valve issues would be my guess.
Old Jul 28, 2010 | 11:56 AM
jagshark89's Avatar
I dont know the name of the headers Ive had them for probably a year and a half now. I have been looking to get some more since they are beginning to crack, probably because i bought them from an ebay store.
I pulled the spark plugs and this is what they look like.
http://s871.photobucket.com/albums/ab275/jagshark89/
im going to put my wideband in the rear header and see what reading i get
Old Jul 28, 2010 | 05:53 PM
jagshark89's Avatar
I just pulled a my codes and I have a code for the ref crankshaft position sensor could that retard the timing enough to cause the glowing
Old Aug 3, 2010 | 08:02 PM
jagshark89's Avatar
I tore the engine down and the timing was spot on. I tried switching the fuel rail. Tomorrow I am going to do a leakdown test tommorow
Old Aug 4, 2010 | 05:49 AM
VQ'ed's Avatar
cat is clogged...
Old Aug 4, 2010 | 06:04 PM
jagshark89's Avatar
i disconnected the exhaust before the cat and their was no change still glowed, would the exhaust leak cause or affect the problem im having
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ac max 92
Sep 17, 2015 07:35 AM
