Sponsored by:
Sponsored by: CARiD
VAFCII in and out setting... where???
Old Aug 3, 2010 | 06:28 PM
Grand_hustle17's Avatar
I just resently got a 3.5" LR MAF housing and i will be installing this as soon as i can figure out where on the VAFCII is the in and out setting, i was sitting the parking lot at work today and said im going to look through the entire setting for this in and out setting, unless there is something i overlooked i just never found the setting, so that stalled me from installing the MAF cause if my calculations is correct it should be a 89" MAF housing and im sure there will need to be fuel added at idle and else where also the setting should be 1in 17out on the VAFCII but i cant find it, somebody help please, i will write down every seeting of my VAFCII most likely tomorrow
Old Aug 4, 2010 | 05:51 AM
Thanks fellas I found it
Old Aug 4, 2010 | 05:54 AM
VQ'ed's Avatar
should be 4 in 4 out normally. unless you have a bigger bore MAF than usual.
Old Aug 4, 2010 | 06:04 AM
NmexMAX's Avatar
dot dot dot ...
Dude, if this was solved I would know the answer. It hasn't been.
The SAFCII is 1/17 .. the VAFC, IIRC does not have that many options.
And It's actually 82mm.
Been through this a few times. Try using the largest contrast of engine sizes (D15 to J35) which is 3/6.
Old Aug 4, 2010 | 04:17 PM
none worked
Old Aug 4, 2010 | 04:18 PM
i just put the stock MAF back on... its on 1in and 1out now... none idle good
Old Aug 4, 2010 | 11:05 PM
Gemner's Avatar
I would set a day aside, pick the largest difference, and if that isnt lean enough, tune it the rest of the way yourself, which you CAN do.
Old Aug 5, 2010 | 06:22 AM
NmexMAX's Avatar
dot dot dot ...
But he has no WB.
Old Aug 5, 2010 | 08:44 AM
ajcool2's Avatar
Originally Posted by NmexMAX
But he has no WB.
Bigger MAF with no Wideband?? Easy way to blow your motor.
Old Aug 5, 2010 | 12:40 PM
Gemner's Avatar
But he has no WB.
oh. well thats step one after you get a vafc anyway so...
Old Aug 5, 2010 | 03:59 PM
what about this???
http://cgi.ebay.com/ebaymotors/WHITE...Q5fAccessories
Old Aug 5, 2010 | 04:02 PM
2000_MAXIMA_KING's Avatar
You can't tune without a wideband, and you need one that datalogs that way you can use the numbers to tune.
Old Aug 5, 2010 | 04:17 PM
couldnt i go off the gauge???
Old Aug 5, 2010 | 04:19 PM
How will you tune it for different rpm intervals? unless you watch it and write it down or something while your driving or have someone else do it actually I dont think you'll be able to do it yourself while driving.
Old Aug 5, 2010 | 04:24 PM
i think im getting how this thing works... so with the digital meter i just go til redline in lets say 3rd gear then it will save the data all through the RPM's or something then i go through and make the adjustment on the VAFC after??? how will i tune with the meter??? im new to this so bare with me
Old Aug 9, 2010 | 06:16 PM
BkGreen97's Avatar
sorry to steal your thread but what are the stock in out settings for a 5.5 gen with a vafc 2?
Old Aug 9, 2010 | 06:22 PM
NmexMAX's Avatar
dot dot dot ...
Doesn't matter, as long as it's the same.
Old Aug 9, 2010 | 06:25 PM
BkGreen97's Avatar
was that a sarcastic remark ? because the car idles lumpy on 1/1 but using 1/17 its slightly better.. but jumps around alot...
Old Aug 9, 2010 | 06:43 PM
NmexMAX's Avatar
dot dot dot ...
The VAFC doesn't go to 17.
Are you sure you're not using a larger MAF housing and a SAFCII? Because those are obviously the settings for it as seen in this thread.
http://forums.maxima.org/all-motor/3...iming-mod.html
Old Aug 9, 2010 | 06:47 PM
BkGreen97's Avatar
im using an apexi neo.. In all honesty I've used the search function and if the question can be answered it will solve alot peoples guesses and problems... What is the in and out settings on an apexi neo for a 2003 maxima with stock maf?
Old Aug 9, 2010 | 06:49 PM
NmexMAX's Avatar
dot dot dot ...
Do you have a WB and is your MAF stock size?
Old Aug 9, 2010 | 06:55 PM
BkGreen97's Avatar
yes i have a stock maf and yes i have a wideband.. and it reads extremely lean or goes extremely riched based upon the maf settings.. When I change the in and out the car cuts off or idles differently... The car idled best on in 1 out 17 but was still very lumpy...
I see from the thread you posted 17 is the correct out but what is the correct in... ?
Old Aug 9, 2010 | 07:03 PM
NmexMAX's Avatar
dot dot dot ...
Well first things first.
Do you have the manual for it and if so, have you read through it to find the relative settings? The 1/17 is for a 5.5 gen using a Q45 MAF(1 is Q45, 17 is 5.5 Gen Maxima). That is for the SAFCII.
Old Aug 9, 2010 | 07:08 PM
BkGreen97's Avatar
i checked the apexi website cudnt seem to find anything.. prior to you having the q45 maf wat were your settings?
Old Aug 9, 2010 | 07:09 PM
NmexMAX's Avatar
dot dot dot ...
17/17
Old Aug 9, 2010 | 07:14 PM
BkGreen97's Avatar
^ you just added to this forum tremendously.. thats what everyone needed to know.. thank you
Old Aug 9, 2010 | 07:22 PM
NmexMAX's Avatar
dot dot dot ...
Not really, we already pretty much knew that ( as I had always suspected, the Neo would be the same as the SAFCII WRT IN/OUTS), it's the VAFCII that still lies a mystery when coupled with the LRMAF.
What would be nice to know if the NEO can be 'manipulated' as the VAFC and have 2 maps combined into 1.
Old Aug 10, 2010 | 06:26 AM
BkGreen97's Avatar
I don't believe so nor do I know the exact method of how to go about doing it... How is it done on the vafc2
Old Aug 10, 2010 | 06:39 AM
NmexMAX's Avatar
dot dot dot ...
If this is true for the NEO, it would then make it a, I believe, 16x2 map.
As for your other question...:
http://forums.maxima.org/all-motor/3...-template.html
http://forums.maxima.org/all-motor/3...ng-advice.html
Old Aug 20, 2010 | 01:12 PM
tedo007's Avatar
faster than you think
Use the the setting 1 In and 4 Out. VAFCII only go to 15.
Old Aug 20, 2010 | 01:40 PM
ajcool2's Avatar
Hmm so NEO>VAFC-II? 32 tuning point instead of 24 hmm.
Old Aug 20, 2010 | 02:33 PM
essential1's Avatar
My axles cry for mercy...
$400 price tag makes it an epic fail in my book... EB can be had for less. Too bad they discontinued it...
Old Aug 20, 2010 | 02:39 PM
ajcool2's Avatar
Yeah you're right. I didnt realize it cost that much.
Old Aug 20, 2010 | 02:49 PM
NmexMAX's Avatar
dot dot dot ...
NEO does have ease of installation on it's side, and shopping around males it cheaper.
Old Aug 20, 2010 | 03:32 PM
essential1's Avatar
True, but as far as instalation goes, the extra 24 wires only belong to the 6 injectors and 6 coilpacks. (IN/OUT for each) And it's only 12 wires if you opt against using the coilpack harness. All 6 injector wires are right next to eaxh other and you have to cut/intercept these which IMO is way easier than splicing. But that is also just personal opinion.
chad9350
Aug 24, 2006 02:16 PM
Puppetmaster
46
Apr 22, 2006 12:29 AM
steven88
Jan 12, 2006 06:53 PM
multiplexor
Jan 7, 2003 05:04 AM
