Anyone do a VQ30-> VQ37 swap?
No the block is different and it is taller so the 30 timing components likely wont fit.
You would need a standalone or the Z/G ECU to make it work. But if you have that engine, it would be POINTLESS to have the old school 30timing on it.
Hm. Never heard of a rwd block, so ur telling me there were two different vq35 blocks for example, one for the Z and one for the FWD applications? I thought it was just the IM? Now I thought the 7th gens had the vq37? I don't really follow them, so I could easily be wrong. Lol
Yes the Z/G have RWD blocks. there is no 37 in FWD platforms
What years would be the same swap process? I noticed when looking for 04 engines, it asked me what style trans I have.. Looks like 02/03 are all the same.
Why are the 04's better? or are they just newer?
Is newer always better? so if I can find an 09, it would be the same deal?
On any of those engines, do I need to re-drill the cams? Or can I just transfer the cam's from my current engine?
Ah ok. Yeah I would just get an 04+ engine. Less miles and I personally havent heard of any oil burning issues from them. As far as the 09's I'm not sure. Im sure its been asked before just cant remember the answer that was given.
VQ37 and VQ35HR will not work without a massive custom undertaking. The deck height is taller (meaning 3.0 timing components would not work), transmission bolt pattern is not the same (meaning you'd need to do something custom to mate a transmission to it), etc.
I already found some 07/08 Maxima engines not far from me. A bit more pricey than the 02/03, but all claim to have less mileage (as expected).
09+ prices get outrageous (which I find strange because demand for them is likely low right now... which is how I got a 03 engine in 05 for $600).
wow thats a first. VQs with tranny bolt pattern differences. im guessing the 350Z found that out looking for more NA power.
VQ35HR?? Sorry for my ignorance, but what "donor" cars am I targeting in my search for a minimal-modification swap? I expect I will do the same process (essentially swapping the timing components and sensors) I did for the initial swap.
Murano, Quest, Altima, Max. You can even use 08 models IIRC, someone just did that swap.
I can't remember where I found that out, I think on a VH/VK forum where guys were swapping transmissions around trying to find out a bolt on solution (there isn't one that anyone's found yet, btw). Also I forgot to mention VQ40s are different too (share same pattern as VQ37s and HRs if I recall correctly).
Get 07-08 altima engine. has HR heads, better updated parts already, plastic intake manifold,
You can make an HR 35/37 work FWD but if you are asking someone how to do it, then you shouldn't be doing that anyways.
is this boosted or NA?
I am confident that if I wanted to do it, I could.. I was only looking for advice and information from people who may have already tried it. Having the information is not the same as having the ability.
And this is a boosted application.
its not really rude its just the truth.
Altima engines seem to be a little cheaper at the breakers.
The OP may have started on the build of his old motor already, but if you planned on spending a grip on a G37, my curiousity jumps out to ask has anyone used the 7th gen 3.5 and did it prove anymore power.... might wanna look into that one.... FWD too
Has this been done running an A32 ecu? What would be the main difference/difficulty over a typical 'timing-hybrid' 3.5 swap? I was under the impression the 3.0 timing cover wouldn't fit because the heads in the 07+ altima and the 09+ maxima were different (http://forums.maxima.org/all-motor/3...tima-im-2.html) - is this confirmed?
I believe the 09+ Max possibly runs a VVEL setup, I would have to check the part number in FAST to see if it is the same or not.
As for the "rude" comment, it wasnt meant to be a rude statement, just a blunt one.... I mean, its one thing to do a swap or conversion when there is a How-To but if its not a straight swap, and it takes fabrication, then there isnt always instructions on what to do and you shouldnt start it and ask how to do the swap...It would be like me asking how to stick a 08 HR motor in my 92 Infiniti G20....
The '09 Max motor is the '07+ Altima motor so no VVEL. No need to waste that tech on a midsize family sedan.
Moar details on the HR motor into a G20!!
A 07-08 Altima 3.5L is very very similar to a 02-08 Max motor. I think the block is the same, and the timing cover is a version of a FWD and HR cover. I dont see any reason why a 3.0L cover setup would not fit.. The timing components are very similar so I would venture that it would work just fine.
Since we're on the topic of your rudeness, where the P10 pics at?
I do not have a junkyard full of various Nissan's to gather all of this information, but I don't see how that would have any impact on my ability to fabricate if needed.
So timing cover/trans/exhuast manifolds all bolt up the same? Who did it? (link please)
Still seems more economical than doing a mild cam (HR/revup) upgrade with a 1st gen 3.5 especially with an EU as an option for the a32's - 07+ altima's with an intake/mild boltons are dynoing between 250-270 at the wheels - even without VTC I'd assume the peak numbers would be close with a semi functional dual VI (RPM controlled) rev increase and some decent ignition maps. Not too sure about the rod bolt ratings in these . . .
edit: This is why I have my doubts itta work: http://forums.maxima.org/all-motor/5...altima-vq.html
I know of one guy locally here who has a 08 altima engine in his 02 max running with the plastic intake manifold setup. I know some parts had to be swapped over but i'm not sure which. it was a nearly stock motor swap setup, not much performance stuff though and i'm not 100% sure on the details...
As for the P10/HR setup, I have to finish the cage work first and some other stuff before I actually finish the engine install... I dont want to super hijack the thread so if you wanted some pics, PM me and i'll shoot you a few of them...
