Sponsored by:
Sponsored by: CARiD
need some wiring help
Old Aug 12, 2010 | 11:54 PM
shrek's Avatar
i need some wiring guru's help
first of all ...i've learned alot here in the org and i don't even have a maxima
im about to install a vq30de into my s13 and im not using a/c,p/s or any other stuff like EGR,EVAP well not even IACV ,so my question is ..to eliminate all of the unused wires on my engine harness ,i have spliced the entire vq30 harness and see that some of them are going to the same place in the case of sensors that need 12v+ or ground ...can i just cut the wires i don't need
i'm sorry if my english is not that good but my first language is spanish and i'm in mexico
Old Aug 13, 2010 | 04:05 AM
99greddymax's Avatar
I would think you can remove power from those acc you're not using..
btw.. how you get a 240 in mexico?
Old Aug 13, 2010 | 07:07 AM
Kevlo911's Avatar
Kevlo for President
As long as you dont cut the wires going to the other sensors, you are find to remove the 12v wires. I would leave the grounds and place them in various parts of the engine bay
Old Aug 13, 2010 | 07:49 AM
ajm8127's Avatar
You should be fine to cut any wires leading to a component of one of the aforementioned systems (a/c, p/s, EGR, EVAP, IACV) Just make sure not to cut any of the important wires (MAF, TPS, crank POS, crank REF, cam POS, injectors, coils, O2 sensors, Absolute pressure, ECTS, KS, fuel pump, etc.) Also, tape up or shrink wrap the ends of the unused wires so the can't make contact with anything. You are going to have a bunch of codes, so maybe don't hook up the MIL either.
Old Aug 13, 2010 | 08:52 AM
shrek's Avatar
thanks ...i got a 240sx in mexico because i live on tijuana(just across the border from san diego) and you can get them imported for like 800 bucks and afterthat you can do whatever you want with it ..as is no emissions and you can do any swap you want(v8,turbo,jdm engines) you only pay a 100 bucks a year for registration
Old Aug 13, 2010 | 07:46 PM
shrek's Avatar
ok now i have another question ...what about the pins that go to the ECU plug??can i just push them out of the plug???
sorry if i sound noob thanks in advance
Old Aug 25, 2010 | 12:10 AM
shrek's Avatar
well here's some pics of what i've been doing with mi wiring for anyone that cares hehe
it started with this
to this
i just got a question..is the map/baro(boost sensor really necessary)i see tha it gets 5v+ from the same place as the tps but i want to know if it is only for emissions ,and the wiring diagram from jwt does not even mentions it
her are some pics of my soon to be installed vq30
Old Aug 25, 2010 | 04:01 AM
nice lookin' engine..
Old Aug 26, 2010 | 08:16 AM
shrek's Avatar
thanks,i hope to installed in the next couple of weeks
vq30+z33 6 speed+s13=win hahaha
Old Aug 26, 2010 | 10:13 AM
ajm8127's Avatar
Yeah, if you want, just push out the unused contacts from the plug. Just be sure to release the locking mechanism first. And then you'll have to release the tab on each contact.
Tyco Impul-Lock Connector Instructions.
As for the Map/Baro sensor, from the FSM:
"The absolute pressure sensor is not directly used to control the engine system. It is used only for on broad diagnosis."
Old Aug 26, 2010 | 02:29 PM
schmellyfart's Avatar
What intake manifold are you using? I'd use the 00vi if possible.
Old Aug 26, 2010 | 07:34 PM
shrek's Avatar
thanks for the tip ajm8127,im goin to post a pic when i finish my wiring now with out a map/baro sensor(i could'nt find it on the FSM or i just suck at searching througth the FSM)..
as for intake manifold ...i can't use any FWD designed IM so its going to be a custom manifold with Pathfinder TB .
Old Aug 26, 2010 | 09:01 PM
I see, good luck with the swap. I look forward to see some track times.
Old Aug 27, 2010 | 06:59 AM
ajm8127's Avatar
Map/Baro sensor info is on page EC-110 of the '97 FSM at least. It's under a section titled "Absolute Pressure Sensor".
Old Aug 27, 2010 | 07:24 AM
I love the VQ.. however i love the lsx's even more.. s13+ls3/7/9= super win!
Old Aug 27, 2010 | 08:36 AM
shrek's Avatar
i would like an ls swap but that is going to be more expensive,i think i could boost the vq30 for less than 3k(including engine,tranny,turbo and other stuff) except an ECU tune
Old Nov 8, 2010 | 08:49 AM
shrek's Avatar
well i have another question..if someone can help me, i got the wiring almost figured out just need someone to confirm some wires for my s13
ECU back up power----pin 80
ECU relay ----pin 24
ECU power ----pin 67,72
fuel pump signal ----pin 11
Old Nov 12, 2010 | 03:02 PM
ampire's Avatar
Sorry I can't help you but beautiful motor dude!
Old Nov 12, 2010 | 09:46 PM
shrek's Avatar
thanks i'll do an update to my build thread soon ....stay tuned hahaha
Old Nov 14, 2010 | 06:00 AM
ajm8127's Avatar
Pin 24 runs directly to the ignition switch from what I can tell. Pin 4 is the coil (signal) to the ECCS relay. Other than that, it looks good.
Old Nov 14, 2010 | 01:52 PM
shrek's Avatar
ok thanks ajm8127
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
