Sponsored by:
Sponsored by: CARiD
busted cam sensor on3.5 swap help
Old Aug 14, 2010 | 06:52 PM
95stillenmax's Avatar
I have a 97 3.5 swap and it shut off going down the road and wouldn't start back like it wasn't hitting so I started checking the timeing sensors and the cam sensor was broken severely and so I was trying to put a new one in and it wont sit flush I got all of the plastic and all the other junk out I jut can't figure out why it would have broken the swap has been done for over a year input appreciated thanks
Old Aug 14, 2010 | 09:24 PM
streetzlegend's Avatar
Was it broken from inside? thats very weird, do you have any noise coming from the timing chain?
Old Aug 15, 2010 | 06:15 AM
From the inside the car turns over with no weird noises except from listening to it you can obviously tell its not firing other than that no noises
Old Aug 15, 2010 | 10:22 AM
bamboomerang's Avatar
I just changed a bank 2 (closest to front) sensor on my 04 - it was cracked internally as the harness was saturated with oil. The car would stall, but it would still start (failsafe mode). They're notorious, when I changed it I plugged in the connecter before I torqued it down because it's so easy to put pressure on the flimsy/awkward angle of the plug-in. If it's not sitting flush, make sure the part itself is not the bank 1, or the crankshaft position sensor (the latter has the plastic arm with the grounding bolt at a 45 degree angle rather than straight on) - the three sensors look really similar and parts guys sometimes mess up, but because the camshaft ones fail more frequently, they're triple the price of the crank sensor.
Old Aug 17, 2010 | 10:40 AM
Anyonehave any idea why this would have broken like this I'm hoping none of the timing came loose
gustavison
Oct 4, 2015 06:50 PM
conansriver
Sep 11, 2015 10:26 AM
asianstyle
Sep 10, 2015 11:30 AM
I<3 A32's
Sep 10, 2015 11:07 AM
maximusrising
Sep 2, 2015 09:55 AM
