cardana24's 3.5 swap
My 3.5 max was faster than my 06 Stang GT before I got the GT tuned. Now that the GT is tuned, its a bit quicker than the max but I was pretty surprised.
man, i know alot of sc people will hate, but i would say a (basic) sc 3.0 w 8-9 psi would get put to shame w a cam'd 3.5 (both 4th gens and tuned 1/4mile) , even at 11 psi it may be a top end catch-up run for the sc'd 3.0.
in for some tuned na 1/4 times (:
i dont have cam's or headers, but if i did id guess around the 270-275 whp/tq range and without needing to wait for redline for full boost, in the track, im sure thats a solid 12.3-12.6 na 4.5, and a 3.0 sc will be around there too.. but Cardana can post some of his 3.0 times at the track ... im not talking about 50 mph - 130 mph highway pulls
you can run Cardana though..
Then I will start data logging and making some adjustments. I am going to hit the dyno once I get it close, and then I will be at the track soon after that. I will probably run at MIR/Richmond Dragway/Dinwiddie. I still need to get some tires though. It's really a tease having to stay below 4k because that is where the car really comes alive.i dont have cam's or headers, but if i did id guess around the 270-275 whp/tq range and without needing to wait for redline for full boost, in the track, im sure thats a solid 12.3-12.6 na 4.5, and a 3.0 sc will be around there too.. but Cardana can post some of his 3.0 times at the track ... im not talking about 50 mph - 130 mph highway pulls
Break in is over
She moves
I glanced over around 6k and I was running around 11 to 1, so there is still room for improvement. I will make some adjustments after I datalog some then i am off to the dyno in a few weeks.
As for tunning, is there a problem tunning based on 2 gear pulls? I am not willing to run to the top of 3rd much less 4th close to where I live
. Should I even spend time doing that or should I just head straight to the dyno?
She moves
I glanced over around 6k and I was running around 11 to 1, so there is still room for improvement. I will make some adjustments after I datalog some then i am off to the dyno in a few weeks.As for tunning, is there a problem tunning based on 2 gear pulls? I am not willing to run to the top of 3rd much less 4th close to where I live
Break in is over
She moves
She moves
. Should I even spend time doing that or should I just head straight to the dyno?2nd gear is a no no , you should be loosing traction and the motor isnt loaded the same. you will feel the difference as you take it upto 12.8s, this is were I have seen the best results. I would recommend logging afrs if your wband has that option, and making 3rd gear pulls, have it tunned to 12.8s once you get on the dyno, then try leaning it out a bit more and seeing if you get positive results, if not bring it back down to the corrections you were already at. get on a highway and take the risk, i did it on a 66, a few pulls a night till it was almost perfect.
so how it feel compared to the 3.0
I did a few 2nd gear pulls from 5-72k to get the a/f pretty close then jumped on the highway at around 2am and finished up with 3rd gear pulls everything below 5k was done in 4th.
btw, I made my a/f slightly richer from 65-72k just to be safe
I think I am going to try to get it close in 2nd, then go rent the dyno for an hour. There are no highways/interstates close to me, and by the time I drive out to one I am half way to the dyno that I use.
Not much to update. I lowered the car a little bit more and got it aligned.
I still plan on going to the dyno in the next few weeks, but I still have not made any corrections via my VAFCII. It has been raining like crazy here the past few days so I have not been driving the car. Hopefully I can datalog a little in the next few days, I have all of my WBO2 stuff wired up in the car, and I have installed the software on the laptop but I have not hooked it up in the car yet. Hopefully I will have more to tell soon.
recommend a wideband full time on the car, i was not planning to, but a month after i dyno'd and was street tuned to 12.8s, i got on the car recently and was at 11.9s accross the board, not sure if it was climate, or whatever, i dropped 10 psi in fuel pressure and got it back up to 12.7s ...wouldnt have never noticed without the wideband bc the car still felt great
So I thought I was ready to datalog but it looks like I am not. Are any of you guys using an Innovate LC-1 set up? That's what I have and they are telling me that I need an AuxBox in order to be able to recorded rpm and other parameters. What are you guys doing? The AuxBox is $250.
I have a LC-1, but it's hooked directly to my Emanage Ultimate. I know LogWorks3 has a record function, but without another input (or inputs) to reference the AFR to, it's kind of useless. To do logging for the purpose of AFR corrections, you really need something that will pull together multiple parameters which is what the AuxBox seems to do. I would say that you need something like the AuxBox or an EU to get some logs that you can use to tune you car.
There is an EU for sale right now here, though I am not certain of what hooking it up to a 4.5 gen would entail. I would think it would definitely be doable especially since you kept the 4th gen ECU. I figure if you are going to spend some more money, you might was well go that route and reap the benefits of the added features (it is a nice piece of equipment). Of course buying a used EU has its risks which you would have to gauge by talking to the seller.
You could also try to use your WBO2 gauge and make adjustments that way, reading it in real time and not logging at all. However, you would probably need another person to help you unless you were on a dyno. Because this method involves buying nothing, it might be worth a try.
I am thinking for the time being I may just make all of my adjustments on the dyno, then before I boost the engine again, I will pick something up that will allow me to log a/f with respect to rpm.
This is what I have
http://www.zeitronix.com/Products/zt2/zt2.shtml
it definitely does suck at first trying to determine what rpm you were at after 3 seconds of recording, etc, but its not too bad once youve gotten used to it. someone here once suggested createing a spike at a certain rpm and using that as the template when u log AFR.
I have been doing a little glancing over, I have an appointment on friday 4/29 on the dyno to get everything thing ironed out, them weather permitting I am going to the track.
what did it put down / run?? im sure you could get the tune in there without the rpm reference just by toying with it and getting used to it. I tuned my car and stillenmaxs at 7 psi with a safc2 just by doing steady 2500-6500 rpm pulls and using the logworks, you dont have the exact rpm refernce but you get a feel for where youre at.
So since your setup is so close to Meximax and 96sleeper I figured I'd post this link so you can avoid this issue before you install the S/C'er.
http://forums.maxima.org/supercharge...some-help.html
I know you already know, but so it is in this thread too. ~264/248. 13.4x@105.xx
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
