Sponsored by:
Sponsored by: CARiD
VQ35HR Valvespring Spec?
Old Jul 25, 2011 | 11:32 AM
MoncefA33's Avatar
All motor guys,
I need specifications on the HR valvesprings.
Spring pressure (open/closed), height, and spring rate. Any info on where I can find them would be greatly appreciated.
Thank you!
Old Jul 25, 2011 | 11:45 AM
aackshun's Avatar
Get a hold of SR20DEN, he's on aim sometimes.
Old Jul 25, 2011 | 12:05 PM
MoncefA33's Avatar
I'm at work. Wanna handle it for me?
Old Jul 25, 2011 | 12:40 PM
NmexMAX's Avatar
dot dot dot ...
Looks as if the charts aren't visible any longer.
Either way, helpful info:
http://forums.maxima.org/all-motor/3...ec-charts.html
http://forums.maxima.org/all-motor/3...revup-etc.html
http://forums.maxima.org/all-motor/3...ta-2007-a.html
I think we all believed double shimming HR springs was the way to go. IIRC I paid 137.87$ for the entire set of items (24 valve springs/48 shims).
Old Jul 25, 2011 | 01:53 PM
dsycks's Avatar
Define "way to go" please.
By this I wonder if this is a price vs performance issue or what? Thx.
Old Jul 25, 2011 | 02:03 PM
MoncefA33's Avatar
Price vs Performance, yes.
Old Jul 25, 2011 | 02:27 PM
NmexMAX's Avatar
dot dot dot ...
Way to go:
Originally Posted by VQ Master
It looks like the VQ35HR spring is the way to go. It isn't linear like the Nismo spring so it doesn't have the seat pressure but it does have much higher full lift pressure and it can go all the way to 13mm vs. the Nismo spring at 12mm.
This means that even with 11mm lift cams you can double shim the HR spring to raise the seat pressure and still not get coil bind (for a total of 12mm effective spring lift pressure).
Thank you Nissan!
edit: Those colors I listed with each spring is the paint color mark from Nissan. And IIRC, some VQ30 springs had yellow.
VQ35HR valve spring part# 13203-JK21A
Old Jul 25, 2011 | 03:14 PM
bamboomerang's Avatar
Free height : 43.85 mm (1.7264 in)
Installation height : 37.0 mm (1.457 in)
Installation load : 166 – 188 N (16.9 – 19.2 kg, 37 – 42 lb)
Height during valve open : 26.8 mm (1.055 in)
Load with valve open : 502 – 566 N (51.2 – 57.7 kg, 113 – 127 lb)
Old Jul 25, 2011 | 03:19 PM
MoncefA33's Avatar
Thank you!
Old Jul 25, 2011 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
Old Jul 25, 2011 | 06:29 PM
05SickSer's Avatar
Yea i should of gotten HR springs/double shims instead of JWT.. But iirc somebody said they were running JWT's at 7800 all day with no issues.. but HR's are running 8k+ all the time so i shoulda done that lol.
Old Jul 26, 2011 | 06:53 AM
NmexMAX's Avatar
dot dot dot ...
Plus the additional potential for higher lift cams.
Old Jul 26, 2011 | 04:53 PM
05SickSer's Avatar
Yea i got the S1's, but i wish i would of gotten a bigger cam now. oh well...
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
