Sponsored by:
Sponsored by: CARiD
My Stage 2 VQ35 Longblock Build from IPP (Import Parts Pro)
Old Feb 25, 2012 | 10:37 AM
taz394's Avatar
Wink My Stage 2 VQ35 Longblock Build from IPP (Import Parts Pro)
Guess i'd make a thread since the motor is about to be done within a week or 2
everything i did on this car/raced etc so far was on a stock block
I plan on spraying from a 200-250 shot of nitrous
i sent out the motor December after i got a deal from IPP after comparing prices with shops all over the country on what started as just a stage 1 short block built
but ended up being a stage 2 Long block build by the time i was done lol
Specs on the new Long block
Wiseco Pistons .020 over 11:1
Pistons ceramic coated bottom / skirts
Eagle Rods
ARP Rod Bolts
L19 Head studs
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block assembled
New OEM Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
JWT C2 Cams
JWT Heavy Duty Valve Springs
5 angle radius cut valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for cams
Heads assembled
New OEM Rev-up Oil Pump
My goal all motor is 320whp and if this doesn't do it i'll be getting Haltech and possibily working on switching to ITB's with e85
Goal on nitrous is to get about a 125-130 mph trap
excited on this baby coming back
Old Feb 25, 2012 | 11:01 AM
t6378tp's Avatar
Turbo 3.5
4Gen or 5.5
Hope you don't pop the stock hg on nitrous
Old Feb 25, 2012 | 11:08 AM
taz394's Avatar
what 6th gens cant have a little fun lol ?
its an HR head gasket on L19's
i was gonna get Tomei or HKS but they said i'd be fine
Old Feb 25, 2012 | 12:41 PM
grey99max's Avatar
LandShark has Cosworth
Yup - the HRs and studs are what I used. That looks like a REAL build! Now you can install the '07+ UIM and LIM from an Altima or Maxima and really breathe! (I'm using a '08 Altima pair).
FYI - If you look at the May 2012 Car Craft page 23 you'll see comments on nitrous sparks plugs on a Chevy build - very relevant to 200-shot nitrous, and also why I'm using NGK R7438-8 stock#4905 plugs. Especially important if you kept stock valves.... Race-Mart has them the cheapest I've found.
Looking good - get 'er done!
Old Feb 25, 2012 | 01:31 PM
Nealoc187's Avatar
SLOW
nice. pretty serious engine for a maxima. good luck.
Old Feb 25, 2012 | 01:37 PM
taz394's Avatar
already got em down coach lol i've already planned on getting em
Still debating on which direct port kit i should go with... already selling my single fogger kit
i need a good dual stage nitrous shot with a controller that will let me spray say 75shot in first...175 in second and 250 in 3rd and 4th
meh its a fun car lol she's been giving good results from day 1 so i don't mind haha
Old Feb 25, 2012 | 02:22 PM
grey99max's Avatar
I figured you were on top of things - but a reminder can't hurt.. You can choose hard-line or flex-line direct-port installation. After doing it, flex-line is easier, to me. You can build your own that way. I still have that boatload of parts. Use the NX Lightning 15201L and 15300L solenoids, a NX Maximizer 2-stage controller, and some good small nozzles and you get two programmable stages of controller. These NX controllers are really easy to program and use. One stage for first gear and the second stage for upper gears. I'm going to change my first stage to drive-by-throttle and limit to 75-shot in first gear for a better launch then go to RPM-control for the upper gears. I've never seen a nitrous controller with more than two separate programs.
Go gettum...
Old Feb 25, 2012 | 02:51 PM
6th gens are so slow
Old Feb 25, 2012 | 03:08 PM
taz394's Avatar
Go gettum...
hmm might have to look into that but drive by wire in first is exactly what i had in mind
yupe ... slow pos i tell you
Old Feb 25, 2012 | 03:50 PM
grey99max's Avatar
The drive-by-throttle setup is set to start at 50% of throttle and you control what percentage of your jets you spray up to 100%. You can program anything you want between 50% and 100% of throttle. I figure that's where I need that kind of control in first gear. Staying below 75-shot should protect the engine even if the ignition advance goes up.
Old Feb 25, 2012 | 05:24 PM
taz394's Avatar
im gonna try to get like bigger slicks upfront so i can do a 100 shot in first gear and then hook with the 250 in second
i think i should be good for a 100% in first at wide open throttle ... its really just test and tune
but this is later planning i don't car about the track ..sure a good pass would be nice lol all i have is the best trap of a little 92 mph in the 8th lol nothing else ... my main goal is really to put some cars i race south the border in check lol
Old Feb 25, 2012 | 05:55 PM
grey99max's Avatar
92 MPH in the 1/8 is really good..!... South Of The Border racing, eh? Is this a road trip? Can I watch?
Seriously, here's the link to the instruction manual for the Maximizer 3 :
http://www.nitrousexpress.com/maxdl/...izer3reva1.pdf
This is great stuff..... but, I amuse easily....
Old Feb 25, 2012 | 06:36 PM
taz394's Avatar
a 125 shot halfway into 1st thru 3rd did the trick on that one lol .. spun but kinda hooked on that run lol
lol you should come down here sometime
Houston is where its at
Im sure you've heard of TX 2k happening in mid march
biggest racing event of the year in the nation lol ... i love houston lol always find races
Old Feb 25, 2012 | 06:37 PM
Rods03Max619's Avatar
Old Feb 26, 2012 | 05:24 AM
ranmas2004's Avatar
If you are spending that kind of money on an engine you should get a Haltech. You will see more power gains. You will definitely get over 320whp with all of that with the Haltech.
Old Feb 26, 2012 | 12:11 PM
krazy6's Avatar
Wish I had money. lol
Old Feb 26, 2012 | 03:06 PM
95naSTA's Avatar
For the heads, do you mean 5 angle on the intakes and radiused on the exhaust?
Old Feb 27, 2012 | 09:50 AM
taz394's Avatar
Hmmm lol might just do all that AND haltech lol ... alot of org locals here in houston said 320whp all motor is def ... so if i can might just try for 350whp im not too worried about all motor ... mostly nitrous lol
still debating on what manifold too ... probably gonna end up making a custom one
lol you don't need alot on your car ...look at you running 12's with a couple of bolt ons lol
yezzir
Old Feb 27, 2012 | 10:03 AM
taz394's Avatar
for anyone planning on doing any builds this shop has THE best pricing ... i researched for 2 months on which shop to go with and found these guys and then realized oh LOL there in town and just drove upthere and dropped off the long block
http://www.importpartspro.com/st2vqloblni3.html
this is the package i got and added on the L19's and ceramic coating on the pistons
and saved almost a $1000 after comparing totals to other shops
They have really really good deals compared to other prices on engine builds
AND this is the shop that Meximax (560whp SC'ed VQ35 4thgen) got all his parts from 5-6 years ago !!!
Old Feb 27, 2012 | 10:50 AM
aackshun's Avatar
.... limp....
Damn racecarz up in here....
Old Feb 27, 2012 | 11:12 AM
grey99max's Avatar
How about a plastic intake manifold? With nitrous?
I've never heard of the TX 2K anywhere ?? - Googled it and it looks like a big deal !!!
Old Feb 27, 2012 | 11:21 AM
taz394's Avatar
hmmm ... have you dyno'ed your car all motor
im still debating you think this is a better alternative then a custom manifold or even a kinetix ... (Well the ports don't match on a kinetix though so idk if i'll go with that )
Old Feb 27, 2012 | 01:49 PM
grey99max's Avatar
No dyno yet. A) I don't care about N/A power, 'cause timing is fuxored for REAL nitrous power, and I'm not racing N/A. B) I'm not done with the development yet. E85 = bigger fuel pump, bigger fuel lines, bigger injectors, gold-plated spark plugs. Already have the huge filter...
Ask SurraTT about his plastic project - see if he has an opinion on the mod. I think it's great. Kinetix is likely a waste of time. I'd like to know more about sparks03's design and why it's supposed to work so well. There might be something good there for us mere mortals.
Old Feb 27, 2012 | 02:03 PM
taz394's Avatar
i do care for all motor power .... just a dif map for it maybe lol
it all depends on what she puts down when i get it up and running
i still like having fun picking on the local maxima's *cough aackshun and maxima.713 cough* and the slower cars lol
and then there's the racecarz crew i hang with lol i just like having fun overall with everyone i guess haha
best of both worlds haha
Old Feb 27, 2012 | 02:22 PM
NYCBL00D's Avatar
I doubt you will get over 320whp on pump. Judging from the 350z guy's builds your build would hit 320ish but they have long tubes. I would guess closer to 310. I hope I am wrong though for both our sakes.
There is a 4.0l stroker that only hits 325whp in a 350z.
Personally I think you will need C8s or higher for cams and an EM that can adjust the cam angles(Hal-tech). The C2s are pretty mild. Any reason you don't want to go with a more agressive cam?
Old Feb 27, 2012 | 03:02 PM
taz394's Avatar
Its a ballpark you never know
Spark made 285whp on bone stock long block ...
a i know a 5AT ser altima made 310 whp on just a Cam Full bolt ons and a tune
well at the end of the day its still a maxima a C8 is too aggressive and aren't ypou suppose to rev high as fuuu on em? lol ... and on nitrous i think i'll be alright with C2's
i had custom headers made with bigger runners/collectors and a bigger custom y pipe made so im good with the exhaust
Old Feb 27, 2012 | 03:32 PM
SurraTT's Avatar
HR Swap Pioneer
^ pics of headers????
edit nvm
http://forums.maxima.org/6th-generat...ic-inside.html
Old Feb 27, 2012 | 04:46 PM
taz394's Avatar
Yupe thats it
compared it to the Cattman / ebay and i had mine made a little bigger
and you can just see the RL y pipe vs my new custom y pipe is much bigger
and while i did all this on the stock manifold stock motor i gained power all motor ... which i thought i might've lost
went from trapping 79mph all motor to 82 mph all motor
so im hoping to see some decent gains with this new motor once i decide on the manifold
Old Feb 28, 2012 | 06:28 AM
grey99max's Avatar
It's good that you have lots of great racers around to run with and learn from. Not much of that here in Kansas, where I have to tow at least 150 miles for a real race. At least my dyno shop is in KC, about 80 miles away.
Old Feb 28, 2012 | 09:04 AM
taz394's Avatar
i race non stop all week long LOL
in the process of Stage 5 Krazy6 weight reduction too lol i've decided to gut it down to be in the 29xx lb range
meximax's Avatar
SC Overspinning Swapper!!
Glad to hear that Kyle and the folks at IPP are taking care of you. It sure sounds like you are going to have a very mean Maxima.
Let me know if you are down in Mexico and looking for proper competition. I'm your huckleberry
Old Feb 28, 2012 | 09:17 AM
taz394's Avatar
oh god lol ima get walked haha
you got the heads and cam on that baby ?
Old Feb 28, 2012 | 09:26 AM
aackshun's Avatar
+1 you get the cam back from that shop Andres?
Old Feb 28, 2012 | 10:57 AM
meximax's Avatar
Si señor. I have finished installing the ported OEM heads and upgraded cam. I have been running around on a first cut tune (running a bit rich) and am waiting on a new throttle body since I think my OEM is a bit restricting up top.
I don't want to hijack your thread, but let's just say that the current baseline heads/cam dyno numbers were a bit above what I was expecting.
Old Feb 28, 2012 | 11:03 AM
taz394's Avatar
Nah its cool lol
a stock viper i'd mess with not you though lol ...
if you need some cars to test it on lmk lol i got a decent little line up of friends finally done with their car that should give you a good race
hmu .. you got my #
Old Mar 6, 2012 | 01:15 PM
taz394's Avatar
a mini bump
anyone know how much power the stock 6thgen fuel rails can support ?
FPR still to be decided
i've bought RC 550 injectors and a Aeromotive 340 fuel pump
Old Mar 7, 2012 | 12:06 PM
taz394's Avatar
A little update lol ... Everything came together suprisngly all at once this morning haha ... a changed a couple of this with the engine build
Final specs on this new long block ;
Wiseco Pistons .020 over 11:1 compression
Ceramic coated pistons
Eagle/SCAT H Beam Rods
ARP Rod Bolts
ARP L19's head studs
Block redecked
Block assembled
Heads redecked
JWT C2 Cams
Heads assembled
Aeromotive 340 fuel pump / RC 550 Injectors and a Tranny cooler came in today aswell
Old Mar 7, 2012 | 12:29 PM
grey99max's Avatar
What? No HR head gaskets with a full load of nitrous? Sigh....
Old Mar 7, 2012 | 12:32 PM
taz394's Avatar
what lol ? they did use HR head gaskets
Old Mar 7, 2012 | 01:02 PM
ranmas2004's Avatar
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
JWT C2 Cams
Heads assembled
