Sponsored by:
Sponsored by: CARiD
SAFC2 ISSUE (3/21/12)
Old Mar 21, 2012 | 03:12 PM
maximusberg's Avatar
ok my buddy and i installed a safc2. wired everything up as it was so to, cleared memory and all. Got all the sensor to check out, the knk sensor as well.. the only issue were having now is the rpm display on the safc2 is reading backwards.
(ex) at idle 6900rpms-7400rpms
WOT = 1500rpms -1000rpms
did anyone else have this problem?
we figured out but just messing around ( if we had the cylinder number set on 16 we were able to get the numbers to read 2800rpms at idle and go up to 8400rpms at WOT but i dunno what else to do here?)
this is on a 2004 maxima 6spd
Old Mar 22, 2012 | 12:13 PM
NmexMAX's Avatar
dot dot dot ...
Make sure you're using the right car type (6cyl) and you used the correct wire for the RPM signal.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
