Sponsored by:
Sponsored by: CARiD
Oil leak HELP....
Old Aug 9, 2012 | 07:10 AM
Hillsboromax's Avatar
Oil leak HELP....
This da 2nd time this has happened in the same spot.. Suggestions?
Old Aug 9, 2012 | 07:42 AM
BigLou55's Avatar
Pretty sure its your front valve cover leaking, I can pretty much guarantee you the rear one is leaking as well, so replace both. With the help of the FSM(Factory Service Manual) and/or Haynes/Chilton repair manuals you can change them yourself. There's even a write-up in the 4th gen section that will help you take everything apart w/ pics. You can either go OEM gaskets or Fel-pro from local parts store. Do not forget the permatex ultra black gasket maker
If you have already had this done recently and its leaking again whoever fixed it probably did not place the permatex in the critical spots(these are pointed out in the FSM). good luck
Old Aug 9, 2012 | 07:52 AM
gilster93's Avatar
Maybe bad gasket?
Old Aug 9, 2012 | 08:41 AM
Thanks BigLou.. I'll get on that..
Old Aug 10, 2012 | 07:12 PM
asand1's Avatar
Originally Posted by gilster93
Maybe bad gasket?
Nope, head gasket is about 8 inches lower.
Old Aug 12, 2012 | 04:13 PM
maxima92se's Avatar
Just a valve cover gasket. replace both DIY and take your time. Like stated download FSM and enjoy. Good luck. BTW this section is for advanced motor work like a complete motor build tuning etc. Just a friendly heads up. Yours is just minor maintenance.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
