Sponsored by:
Sponsored by: CARiD
New Custom Intake Manifold + 4" Intake + 2009 TB + LOTS OF NAWZ
Old Dec 29, 2012 | 09:55 AM
taz394's Avatar
I've been swamped with work/school but ain't backed down ... i got with a local shop that has built and put impressive gains in a few different NA cars and we sat down and decided to go for it ... i bought a 2002 maxima IM (NO EGR ports etc .. i have EGR deleted anyway ... makes things cleaner )
Not too crazy about all motor numbers ... but 320whp would be nice lol
anything over 300 is cool
Plan
-4" CAI with an air box / Custom Maf housing
-2009 Throttle Body and harness
-Ported Runners on the stock manifold
-Ported Lower intake manifold
-Single fogger tap for a wet kit
-Direct port Tap for my primary kill mode
-Enough flow to put me easily over 300+whp
everything was done the right way ... flow was measured in EVERY runner
Old Dec 29, 2012 | 03:09 PM
SurraTT's Avatar
HR Swap Pioneer
excited to see how this turns out! Dynojet please!
Old Dec 29, 2012 | 03:13 PM
taz394's Avatar
yezzir ... it ill be done on a dynojet
Old Dec 29, 2012 | 05:12 PM
schmellyfart's Avatar
Plan
Nice! Stock flow numbers on the right, I assume?
Old Dec 29, 2012 | 06:35 PM
taz394's Avatar
yupe
#2 they said wasn't much of a gain they asked me if i wanted to make some changes to raise that up aswell but i was like nah man im not that worried about it lol
Old Dec 29, 2012 | 06:49 PM
MaxPR0908's Avatar
In for numbers!! Good luck!
Old Dec 30, 2012 | 12:08 PM
Unklejoe's Avatar
Please dyno before and after on a DJ. Yours looks much better than mine so I would expect at least 270 all motor.
For your stock flow, did they do this measurement with the throttle body on or what? What exactly was the setup? This was measures not simulated right
You running a built motor correct?
Old Dec 30, 2012 | 09:27 PM
taz394's Avatar
I made 260whp on stock tb/manifold/2.75 intake on a mustang dyno and only revving to 6400
Yes Its a fully built long block
Old Dec 31, 2012 | 02:46 PM
Unklejoe's Avatar
Nice. I made that with my previous manifold (3.5" intake/maf/3" exhaust) so you should have no problem hitting at least close to 300 with your new setup
Old Jan 1, 2013 | 06:59 PM
taz394's Avatar
Hopefully lol ... I have a very well known uprev tuner doing the tune so lets hope he delivers
Old Jan 1, 2013 | 08:16 PM
nishfish871's Avatar
Very interested in NA numbers before and after. PM sent about that shop.
Old Jan 1, 2013 | 11:34 PM
krazy6's Avatar
How much giggle juice is planned for kill mode?
I vote for 75 in the single and 200 in the direct port.
Old Jan 2, 2013 | 09:44 AM
taz394's Avatar
yupe ... 75 for first
200/250 for the direct port
Old Jan 3, 2013 | 12:27 PM
krazy6's Avatar
Awesome! Car is gonna move out!
Old Jan 3, 2013 | 08:59 PM
grey99max's Avatar
LandShark has Cosworth
Yeah...... Hmmmm. I love the smell of fried tires in the evening air.
Old Jan 3, 2013 | 09:58 PM
Rods03Max619's Avatar
Good luck on the 300plus whp....
Old Jan 4, 2013 | 08:52 AM
taz394's Avatar
once it catches ofcourse lol ... hopefully those 28" slicks do some justice lol
Thanks mate
Old Jan 4, 2013 | 11:05 AM
FastnFuriousMax's Avatar
I don't think you will see 300whp NA on a stock cam but I hope I am wrong.
Old Jan 4, 2013 | 11:14 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Should be right at 3oo, high 290s.
How much u guys looking for for another Mani. May be 3 interested already
Old Jan 4, 2013 | 02:55 PM
SurraTT's Avatar
HR Swap Pioneer
he dont have stock cams,
i think the motor is BUILT
right?
should be over 300 with no problem.
Old Jan 4, 2013 | 07:42 PM
shrek's Avatar
hi guys dont want to threadjack but where do you people buy your materials for manifodls? ebay ....is it ok to use something like this?? http://www.ebay.com/itm/3-5-89mm-90-...33fab8&vxp=mtr
Old Jan 5, 2013 | 08:46 AM
taz394's Avatar
You'd have to contact the shop
  • 4073 FM 3538
  • Sealy, Texas 77474
Phone(832) 421-7422
Email Sales@DDPerformanceResearch.com
Website http://WWW.DDPerformanceResearch.com
right?
yupe
specs on the new engine for those who missed my build thread
Wiseco Pistons .020 over 11:1 compression
Ceramic coated pistons
Eagle Rods
ARP Rod Bolts
ARP L19's head studs
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block assembled
New OEM HR Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
JWT C2 Cams
JWT Heavy Duty Valve Springs
5 angle radius cut valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for cams
Heads assembled
New OEM Rev-up Oil Pump
The shop gets it from a local materials wholeseller here by Houston ... i wouldn't get anything from ebay
Old Jan 5, 2013 | 11:20 AM
MaxPR0908's Avatar
That sound excelent! Good luck!
Old Jan 7, 2013 | 06:36 AM
ah C2s...then my bet is 290 depending on your dyno of choice.
Old Jan 7, 2013 | 06:47 PM
krazy6's Avatar
Who cares what it makes. This thing should trap a lot of mph that's all that matters.
Old Jan 8, 2013 | 05:57 AM
ABIGBRAIN's Avatar
Track dyno is all that matters.
Old Jan 9, 2013 | 10:40 AM
krazy6's Avatar
It's the most accurate one!
Old Jan 18, 2013 | 06:51 AM
what did the car make with the IM?
Old Jan 21, 2013 | 12:20 PM
taz394's Avatar
haven't put it on yet ... no time sigh lol
started on it little by little ... but going started to school and still working 60+ hours = no bueno
Old Jan 21, 2013 | 12:41 PM
did you have to add alot of fuel? Did you afr change much before retuning?
Old Feb 28, 2013 | 12:42 AM
Any update....
Old Feb 28, 2013 | 04:41 AM
sprocketser's Avatar
Wow , I like these , subs d .
Old Apr 27, 2013 | 07:37 AM
Maximeltman's Avatar
any update on this?
Old May 8, 2013 | 08:41 PM
aackshun's Avatar
This car has suffered a fate worse than the Red car.
Running, but too lazy to take it to the track.
Limp.
*stirring the pot*
Old Jun 8, 2013 | 01:55 PM
taz394's Avatar
Limp.
*stirring the pot*
*update*
Car is running with a 2009 Throttle body and only thing left is to install direct port with the fuel cell and go get it tuned
I MIGHT just go get it tuned for all motor for now because for the past 5 months I've been saying "IM GONNA INSTALL THE DIRECT PORT THIS SUNDAY"
lol ... Not given up yet people ... just life taken over and more priorities at the moment.
I drove her a couple of days ago after a long while ... its running incredibly Lean so I don't do much but just a low rev cruise around the neighborhood
Old Jun 8, 2013 | 07:03 PM
grey99max's Avatar
*update*
Yea! you're still in the game!
Old Jun 25, 2013 | 06:37 AM
aackshun's Avatar
*update*
You have osiris right? Just limp it over to my house and we'll get it done in a day.
Maxboy23
Sep 9, 2015 10:37 AM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
iflexsteel
Sep 2, 2015 08:04 AM
