Sponsored by:
Sponsored by: CARiD
Sharing my build...
Old Mar 21, 2013 | 11:49 AM
MoncefA33's Avatar
Sharing my build...
So I had a cammed DEK awhile back. Switched to a hybrid VQ35 and I blew it up. So now I has one of these...
- VQ35DE block, stock pistons and rods - bored 40 over.
- ACL Race main bearings & rod bearings
- ARP head studs, main studs, rod bolts
- Polished 350Z crankshaft (same as A33 model)
- Ported/worked 3.0 heads with JWT S1 cams and HR valvetrain (compression ~11.5-11.8)
- SSIM, PFTB, 82mm MAF
- e-Ultimate/AEM wideband
- v2OBX/equal downpipe
- 3" testpipe/3" Cattman
- STOCK 5MT, Exedy stg2 clutch , Fidanza flywheel
Haven't done much for tuning aside from cleaning up the closed-loop operations, I am pulling a couple of degrees of timing across the board. One of the welds on my v2OBX header broke, welded it back up, sounds great, car is making great power, and spins my new Toyos like crazy in 2nd gear.
Stock rev limit for now, going to tune to 7500 RPM, 12.5 AFR, and will leave timing alone until I get on the dyno.
Does anyone have a setup like this? Any suggestions on setting up timing #s at redline?
PICS below.
Quick VIDEO: lots of wheelspin
Old Mar 21, 2013 | 11:54 AM
MaxPR0908's Avatar
Nice!! In for dyno numbers!
Old Mar 21, 2013 | 01:21 PM
Hadou-kai's Avatar
stock pistons 0.040 over? where can i purchase those?
Old Mar 21, 2013 | 02:47 PM
Redline Maxima's Avatar
I have a similar setup except with 3.0 JWT s1 cams, wiseco 8.8 comp pistons and eagle rods. Had a problem with cycl 4 and I'm getting all the bearings replaced again.
Old Mar 22, 2013 | 08:24 AM
MoncefA33's Avatar
Yea man, can't wait to see what it makes.
My machine shop got them from Topline INC.
You going with a boosted setup?
Old Mar 22, 2013 | 08:47 AM
NmexMAX's Avatar
dot dot dot ...
How TF did I not see this thread!
Nice work Cefffy! This is awesome!
GM 3.6's don't got ish on this ... besides DI, but yeah I like this.
Old Mar 22, 2013 | 09:10 AM
MoncefA33's Avatar
It's sick. Love the torque and response and top end power.
Old Mar 22, 2013 | 09:37 AM
I<3 A32's's Avatar
Your using the 3.0 heads for more compression?
Old Mar 22, 2013 | 10:55 AM
MoncefA33's Avatar
Old Mar 22, 2013 | 11:00 AM
NmexMAX's Avatar
dot dot dot ...
Dude ... this is ... yeah. First of it's kind. Don't want to sound too overexcited but everyone talks about doing this that or the other, and you went and did. Rare on most forums.
Glad someone finally did it, contrary to what everyone has said/posted about the 3.0 heads.
Was there a reason why you went that route?
Kept tabs on it on FB a little, but didn't know the guts/nuts/bolts of it til now. Assumed it was a run-of-the-mill VQ35 swap.
Old Mar 22, 2013 | 11:46 AM
MoncefA33's Avatar
Yes the reason I had was because my heads have had extensive work to them. So the compression bump and the increased flow over stock VQ35 heads was a no brainer. Massive port job, flawlessly polished exhaust, and 5 angle valve job.
The intake ports were port matched as well to fit the VQ35 LIM and SSIM.
Old Mar 22, 2013 | 12:31 PM
I<3 A32's's Avatar
Your going to have to run 100 octane
Old Mar 22, 2013 | 12:32 PM
MoncefA33's Avatar
Nope. 91 pump gas.
Old Mar 22, 2013 | 12:47 PM
Yea my setup is for boost
Old Mar 22, 2013 | 12:58 PM
I<3 A32's's Avatar
You have any work done to the combustion Chambers
Old Mar 22, 2013 | 01:05 PM
NmexMAX's Avatar
dot dot dot ...
Manufacturers have been doing this for years. Most of the new HO V6's are 11.5 or so CR, and are able to run on pump gas, 91.
Hmmm ...
Reason enough. Makes sense, hadn't thought of that.
Old Mar 22, 2013 | 01:31 PM
I<3 A32's's Avatar
The reson combustion Chambers have anti dentition spots,cut i had a honda a jdm sohc zc compression 12.57 to 1 jdmdohc zc pistions usdm d16y8head blocks intake manifold 2 1/2 in exhaust on 380 cc injectors on 91
Old Mar 22, 2013 | 02:06 PM
MoncefA33's Avatar
The place that did these heads stated that they modified the combustion chambers for knock suppression. (DPR Racing)
Old Mar 22, 2013 | 02:17 PM
sprocketser's Avatar
Wow , love your engine Moncef , sub d
Old Mar 22, 2013 | 02:36 PM
LeGaspardVQ's Avatar
Love the setup. Congrats on getting it done. The car sounds healthy too. Props
Old Mar 22, 2013 | 02:47 PM
Have a look at the oil passages , might be debris in there .
Saw your name somewhere else ! how are you mate !
Old Mar 22, 2013 | 02:55 PM
I<3 A32's's Avatar
We did it at shop **** was a Pain in the *** the y8 come with it alrrady we just ook off the sharp edges on the Chambers i had 310psi in each cylinder dry wet 332 +/-5psi
Old Mar 22, 2013 | 09:09 PM
ABIGBRAIN's Avatar
32 degree radias chamber cut for the added bore?
Andy
Old Mar 23, 2013 | 12:59 PM
Did you do the Cloverleaf Mod in there also Moncef !
Old Mar 24, 2013 | 12:25 PM
95naSTA's Avatar
Sick setup. Can't wait for #s.
Old Mar 24, 2013 | 10:33 PM
Agreed. Subscribed!
Old Mar 25, 2013 | 07:28 AM
MoncefA33's Avatar
Thanks everybody for the support. I will bump this thread with dyno #s once they become available. I plan on getting a street tune going once the snow melts and I do one more oil change and you will get to see more video.
Old Mar 25, 2013 | 07:15 PM
Rods03Max619's Avatar
Very Nice, Inspiration right there....
Old Mar 26, 2013 | 01:46 PM
Aaron92SE's Avatar
NWP Engineering.com
Lookin good!
Old Mar 28, 2013 | 06:30 AM
MoncefA33's Avatar
Old Mar 28, 2013 | 08:20 AM
CallMeThatOneGuy's Avatar
"Oh sh** a yellow light!" *floors it*
Old Mar 28, 2013 | 01:29 PM
Aaron92SE's Avatar
NWP Engineering.com
Old Mar 31, 2013 | 02:18 PM
niceguy's Avatar
Nice build and DPR head work, wow nice.....
Old Mar 31, 2013 | 02:38 PM
You get that thang resolved?
Old Apr 9, 2013 | 11:05 AM
MoncefA33's Avatar
Misfire is somewhat resolved - it's due to one of the remote mounted coilpacks arcing on a A/C hardline by the firewall. So I need to get stiffer mounts and relocate the coil to ensure it does not happen again. It doesn't happen often but when it does I get
Yeah man, nobody really even knows about DPR Racing, but my tech (who has built Supras DSMs Terminator Cobras etc) was shocked at how great the port job looked and the polished exhaust side.
Old Apr 9, 2013 | 04:02 PM
niceguy's Avatar
I learned about Dan Paramore more than 10 years ago from reading SCC lol...actually spoke with them back in 2001 about building the head of my then daily driver '93 Altima KA24DE. I just couldn't swing the money back then which I regret- they all but guaranteed me about 20whp+ on top of bolt ons on that particular motor with the proper header/exhaust setup.
They're one of the very best in the country period, congrats...
Old Apr 11, 2013 | 06:26 AM
Maximeltman's Avatar
Wow this build is so cool, very nice!
Old Apr 13, 2013 | 12:35 AM
Quickywd01's Avatar
Nice!
James92SE
142
Jan 2, 2024 09:23 AM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
Marc2theMax
Sep 28, 2015 08:13 AM
