Sponsored by:
Sponsored by: CARiD
Stripped bolt from clutch to flywheel - Help?
Old Apr 11, 2013 | 06:38 PM
Max_Gator's Avatar
Replacing my clutch.
Unfortunately, I stripped one of the bolts from the clutch to the flywheel. I was being extremely careful, using torque wrench and torquing to spec. Oh well. It is not badly stripped since I stopped immediately.
Obviously, the most conservative fix is to replace the flywheel.
However, I'm wondering if I could go without one bolt out of the three bolt set - middle if it matters. And if so, I'm guessing I should completely remove the bolt to prevent it from coming loose.
The only other thing I can think to do is to threadlock it down. FSM doesn't call for treadlock on those bolts.
Any experienced suggestions would be very much appreciated.
Thanks.
Old Apr 12, 2013 | 02:26 PM
vipervadim's Avatar
I like Maximas
you can go without 1 bolt. as long as the other 8/9 bolts are holding it in.
I had that issue for 3-4 years without any problems, until the clutch wore out..
make sure you align the clutch exactly in the center, and use a torque wrench when you tighten those clutch bolts
^^^can you find the missing bolt?
the proper way to remove the stripped/broken bolt would be to drill it out a little bit and use a reverse thread bolt extractor to try to get the rest of the bolt out the threads.
Otherwise it's drill it out completely and retap the threads.
they're M8x1.25 thread pitch, I believe
Old Apr 14, 2013 | 11:11 AM
asand1's Avatar
You were only torquing to 25-33 ft-lb right?
Old Apr 16, 2013 | 04:39 PM
Max_Gator's Avatar
Thanks. As it turns out, it was just the bolt.
Very strange. the top threads of the bolt stripped. I got a new bolt and it torqued fine.
I don't recall the exact torque but it was whatever the fsm said.
Of course..... After everything was back together, my transmission failed. I knew it was on the way out but wtf? 200k miles so not really surprising.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
