head unit installation question
Old Jul 10, 2002 | 08:57 PM
toucansma's Avatar
Hi,
Yeah I know this is a novice question, but I was wondering if anyone has a good page on headunit removal (preferably non-bose) for a 4th gen max. I have searched the archives but most the links (ie installdr) seem broken. I have taken them out of other cars before so I am hoping this one isnt too bad(however they also were column shifts not console). Any advice is appreciated! Thanks!
Sam
Old Jul 11, 2002 | 06:08 AM
loudmaxima's Avatar
Re: head unit installation question
disconnect battery, turn key to on , pull parking brake, put shifter in neutral, pop the little plastic cover off that, pop the cover off where the a/c vent and the clock are, ashtray removes with one screw- remove it, four screws hold the entire climate control, radio, and the pocket (two at the top, two at the bottom), pull it out, two screws on each side of the radio...you usually have to remove the screws on one side of the climate control to open the metal cage enough to get the radio out....then it goes back together same way
Old Jul 11, 2002 | 06:49 AM
H.N.I.C.95's Avatar
www.installdr.com
Old Jul 11, 2002 | 07:13 AM
blizz20oma's Avatar
I'm so hood
The stereo section on www.dereckwillis.com got me through pretty easily. I was able to do it without removing the shift ****. Watch out - he's not kidding when he says those stock screws are in super-tight. I ended up having to drill three of mine out. Anyone want a Bose deck with metal shavings and one piece of threading still inside?
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
BunkyMaxima
Aug 22, 2015 12:58 AM
MikesChevelle
Aug 9, 2015 11:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
