4th gen maxima dome light or courtesy door light tiggers?
Old Jul 11, 2002 | 08:47 AM
1MAX2NV's Avatar
Is it a negative trigger? Are the dome light and the door lights run on the same wire or are they separate coming from the Body Control Module? I'm looking to trigger my underbody neon via this wire. Ideal situation would be whenever I hit the key fob to unlock the doors, the neon lights would come on. After I get in and start the car, the lights goes off. If I turn on my interior dome light, the neon would come on too. I believe the dome light turns on via two methods. By using the overhead switch or via the trigger from BCM. I guess I might not get the dome light switch trigger to work correctly since I most likely would tap wire coming from the BCM. Anyone know where I can get easy access to this negative trigger wire?
Old Jul 11, 2002 | 06:17 PM
mb1's Avatar
mb1
heres a link to the wire color codes for all maximas. right click and download. enjoy.
http://members.directvinternet.com/~...5/htdocs/1.zip
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
