The Best Sound Setup - Please give me some advice
I want to add a subwoofer with a nice amp. I want it to run on the stock bose system (I like the way it sounds). What do you guys recommend? Alpine, fosgate...kicker...? I'm planning on having a custom made box to match my drunk. I leaning towards a single 15 incher? I'm from NYC if anyone wants to meet etc. Also, will it slow me down to the point I will need to take out the sub for better performance. I'm getting/have lots of performance mods and do not want to lose performance.
Re: The Best Sound Setup - Please give me some advice
get a 4 cube box....slot port it to 35hz, stick a kicker 15 L7 dvc 4ohm in there, link it with a cadence a7h or jbl bp1200.1, and your ride will slam...that is a good value system right there..
yea definitely in the wrong spot.
I'm also looking for subs and deciding between some old discontinued but kicking rockfords or JL's...everyone says JL's are strong and clear but the price on rockfords for the wattage (discontinued ones) is too good to pass by...i found this one spot...800 watts for 150 bucks...obviously i can get cheaper but that's just a start...
wattage ratings vary between manufacturers...fosgate may rate their HE2 @ 400w rms and 800 w peak...but jl might rate the same size w3 @ like 250 watts rms...but the jl can most likely take 500 wrms much easier than a fosgate would....it is all about the way they manufacturer rates their subs...dont just look at wattage alone, there are many other specs that play a role in the way the sub performs...just because pyramid says their subs hand 1000 watts...it dont mean sh*t...you will be lucky if the sub survives a good 200 watts rms from a US Amps or Xtant.
What's your budget? There are a LOT of good 15s out there. If you're really worried about weight, you probably are going to want a small sealed box too.
You shouldn't decide on what sub to buy simply based on the ratings. JLs are underrated in terms of power handling. THey can take a lot more than what they are rated for without any problems at all. I have a friend who has 2 JL 12w3s running off a RF 800.2 so they're getting over 400 watts a piece. I'm pretty sure they're rated a little less than that and he has been running them for a while without any problems whatsoever. If you want good cheap subs check out Kicker Comp VR (less than $100 a piece). Also there are a lot of lesser known sub brands that will definately outperform similar priced mainstream brands in the same price range. Look into Resonant Engineering and Elemental Designs.
Re: Re: The Best Sound Setup - Please give me some advice
Originally posted by ivelweyz
Got to the AUDIO forum, that's why they made one u know...
eric
Brahma is a freakin killer sub....how much did that cost u? I would take one over a W7 any day.
Yeah, I blew my IDMAX and so I was looking into getting another sub, heard some REs & the e12a and they sounded great. Didn't want two subs though so I went Brahma.....
eric
Re: Question about subs.
Originally posted by DR0832
Anybody know anything about Diamond Subs? I have a friend who sells them retail, and he lives by them. He says they out perform jl, and other good companys?
--Don
Originally posted by bacid
i've also heard the brahama was an excellent sub..
comparable to idmax, w6, mass 2012 & evo , etc...
good balance of SQ and SQL and crazy loud.
have any of you with the brahama been metered yet?
eric
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
