Running a system with stock Bose system...
Old Jul 18, 2002 | 10:42 PM
SoccrZ's Avatar
Is it possible to run amps and subwoofers with the stock Bose head and speakers? I know people have probably asked this many a time, but "search" never gives me very good results. I don't know a TON about mobile audio, but I know some, so if you can help please respond! Thanks. -Dave
Old Jul 19, 2002 | 07:32 AM
magnetik's Avatar
This is what you need to add a sub and amp to the Bose system.
http://www.sounddomain.com/sku/PERNISSANAR95
It plugs into the back speaker harnesses and has RCA outs. Make sure your amp has a low pass otherwise it will sound like crap. This is not the cleanest method (because it converts the BOSE high level signal to low level) but the only one that will let you keep your factory intact without rigging.
Old Jul 19, 2002 | 08:14 AM
SoccrZ's Avatar
How much is that adapter? And when you say "back speakers" you mean the rear speakers in the car right? Thanks for you help, I appreciate it.
Old Jul 19, 2002 | 08:28 AM
magnetik's Avatar
It's $49.95 on sounddomain... They plug into the rear speaker harnesses and convert the highlevel to RCA's. It lets you keep the rear speakers and add a sub or replace the factory amps. Here is the description...
"This adapter allows you to retain the OEM receiver and replace the rear OEM amplifiers and speakers with aftermarket components. You can also retain the entire OEM system and use this adapter to add an amplifier to the existing system. Direct plug in adapter to replace amps or add an amplifier. Note: not for use with Nissan Quest (use FDAHW)"
Old Jul 19, 2002 | 10:34 AM
SoccrZ's Avatar
Okay that makes sense. I already have an amp that I got on ebay, but its pretty crappy so I may get a new one. Thanks for all the help!
Old Jul 21, 2002 | 10:13 AM
spb2k2's Avatar
where would u plug the two ends if u would use it on a 2k2 with bose
Old Jul 21, 2002 | 11:40 PM
studman's Avatar
spb2k2:
http://forums.maxima.org/showthread....hreadid=138133
The above link provides a clean way to install aftermarket amps, subs, and/or speakers on your 2002 Max with BOSE. It's a little more pricey than the converter magnetik recommended, but it's also BEFORE the BOSE amp, which has it's own internal crossover. In effect, you get a full range signal from the back of HU, instead of a crossovered signal from the rear speakers.
Either way, make sure your amp has a low-pass filter/crossover in it to get rid of all the highs. Highs + Subs = Crap
Old Jul 22, 2002 | 07:42 PM
spb2k2's Avatar
thanks dude
melteye
May 16, 2016 12:02 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
