Amp Wiring Kits
Old Jul 19, 2002 | 07:39 AM
samabra's Avatar
Amp Wiring Kits
Hey guys, I've got an amp and two subs, but now I need the wiring. What do you suggest? I have a 300 watt mono sub amp, and two MTX 8000 12" Subs. Brands and maybe where to look? I was just going to go to Fry's and pick one up, but I wanted to know what to look for.
Chris
Old Jul 19, 2002 | 08:48 AM
slickonetoo's Avatar
Re: Amp Wiring Kits
Chris
amp "kits" all serve the same purpose and the only difference between different kits are cosmetic...now their is some that are 4 ga and some that are 8ga just depends on if you want to add in the furure...as for wire, wire is wire if your comparing 4ga to 4ga...1 kit may have better rca's than another, and I would recommend you spend the money on rca's over over a prettier wire than the other...
that will be the only differences in install kits really, the rca's...if you do plan on adding later, make sure you get a D block that fits the needs for add on's later..you also want to take into consideration now for future upgrades when it comes to power wire too...if you plan on adding in future, get 2ga...it is really easier to run your main's 1 time instead of 2 or 3..........lol
Old Jul 20, 2002 | 05:55 AM
samabra's Avatar
Thanks for awnsering my newbie question
Chris
Old Jul 20, 2002 | 03:23 PM
nismo240sx's Avatar
at walmart, in the automotive section, they have 4 gauge scosche 4 gauge wiring kits w/ all terminals, etc for around 22 bux. i work there, so i get a little discount, but i have yet to see any other place have a deal like that on wire...except the internet, but shipping will put you up over the cost of the walmart wire.
eric
The Frye
Sep 2, 2021 11:03 AM
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
