how to install rear speakers?
pain in the ***
there are two rings underneath the rear seat. pull those to remove the lower seat.
You'll see 4 bolts I believe. There are two more in the ski access, you just pull the plastic and vinyl piece up.
Remove the rear seat backing. Now you have to remove the C-pillar trim. I think you just yank at the bottom and work your way up. A trim panel pry tool is very helpful.
Remove the rear deck. There are a few clips, but it just just pull up and out. Speaker screws are on the top.
If you don't mind waiting, I can scan the crutchfield diagram for you.
good luck
good luck
jskirwin
Jun 8, 2016 08:49 AM
melteye
May 16, 2016 12:02 AM
Huttig2009
Sep 25, 2015 03:31 PM
