I took a peak under...
Old Jul 29, 2002 | 06:19 PM
dracip's Avatar
... the rear deck of my 2k3; on the right, there is what look like an upside-down amp, marked "Bose" : is it the processor/equalizer for the system? Also, just under the sub, there is a brownie-sized metallic box : is it the sub amp?
Old Jul 29, 2002 | 06:53 PM
Stereodude's Avatar
The black box is the amp. The brown thing under your sub might be the connector for it? The amp for the sub is built into the sub.
Stereodude
Old Jul 29, 2002 | 07:20 PM
dracip's Avatar
Stereodude
So, could someone tap the wires (line-level signal,I assume) bound to the Bose amps using rca connectors, then straight to aftermarket amps?
Old Jul 30, 2002 | 03:30 AM
Tony Fernandes's Avatar
People have done this, but I was always suspect b/c I always seemed to find that different people had different opinions as to what wires went to what. There are adapters available that tap into these wires behind the head unit instead of at the amp. I would imagine that the wire colors would be the same at both locations and a knowledgeable person could jury-rig it to work just fine. I myself found it difficult to start splicing into wires with my $30k+ car. So I just replaced the whole Bose system from scratch and am very happy now.
Tony
Old Jul 30, 2002 | 09:04 AM
dracip's Avatar
Tony
That's an option i'm considering too. Thanks!
Old Jul 30, 2002 | 01:11 PM
If that's the case, check out this thread. Hope it helps.
Tony
Old Jul 30, 2002 | 07:27 PM
dracip's Avatar
That's pertinent info, indeed. I'll print it!
mclasser
Aug 23, 2015 09:32 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
emax02
Aug 5, 2001 11:23 AM
CandiMan
Jun 27, 2001 04:46 AM
