Does Anyone build boxes?
Old Aug 10, 2002 | 08:21 AM
ThumpinMaxima's Avatar
Im looking for someone to build me a ported box...I need this box to hold 2 10" Xtant 'Z' series subs...1.25cf is needed...could neone build me a box...(ported) If so...whats it gonna cost me?
Old Aug 10, 2002 | 08:27 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Does Anyone build boxes?
You ae better of going to a local shop, or finding someone that lives near you to do it. The shipping would kill ya.
Or why not do it yourself?
--Don
Old Aug 10, 2002 | 08:43 AM
its not for me its for a friend, tweeter wants 200$ for a ported box...F*** that....how much would shipping run me? how much would a box run me? I live in Southern NH, rite near mass...
Old Aug 10, 2002 | 08:46 AM
Pearl96Max's Avatar
Well if ya built it yourself, it would run ya approx. $30 and a trip to the store for the materials.
--Don
Old Aug 10, 2002 | 08:51 AM
well...maybe ill try...can you help me, this will be my FIRST box...
I want this to be ported...It needs to hold 2 10" subs...and have 1.25 cf per sub, I THINK!!! the subs are Xtant 'z' series...please help
Ghee don...seems like you sit on the comp all day
Old Aug 10, 2002 | 08:54 AM
Pearl96Max's Avatar
LOL Im just thread whoring today. I can help ya out, but being that it is youre first box, try for a sealed enclosure, it is easier to build and will give better SQ.
--Don
Old Aug 10, 2002 | 08:59 AM
man o man...this isnt fun :-/ Im just gonna make him buy one, why should i go through all this trouble for him :-P
Old Aug 10, 2002 | 09:01 AM
Pearl96Max's Avatar
If you build it, you can charge him $100 as opposed to Tweeter @ $200. Itll cost you about $25-$30, and you will have enough material left to do several more.
--Don
Old Aug 10, 2002 | 09:03 AM
Don, MY FINAL question, I think
Subs say they need 1.25cf will I be hurting them if I only give them 1.0cf?
Old Aug 10, 2002 | 09:04 AM
jmax
Yeah, unless you have woodworking or composites experience I wouldn't attempt a ported box as the first box. $200 is actually quite low for a custom box from an install shop. Considering construction time, shop tools, etc. Most shops charge betweeen $25 and $75 an hour for install time. The materials cost for a typical box are very low, as Don mentioned.
Old Aug 10, 2002 | 09:06 AM
Pearl96Max's Avatar
You will not be hurting them, fill the interior of the box with polyfill. Most speakers have flexibility with the size they are in. If is not EXACT it should not hurt them, unless it was a really high end/extremely sensitive speaker.
--Don
Old Aug 10, 2002 | 09:08 AM
wats polyfill??
Old Aug 10, 2002 | 09:14 AM
Don I lied, I have another question...the friend of mine who is putting these 2 10" Xtants in his car...already has a Bazooka bass tube...now...when he got this bass tube, he bought a 8 gauge wiring kit...is this enough for his 2 10's now, or should he invest in a 4 gauuge wiriing kit?
Old Aug 10, 2002 | 09:27 AM
jmax
whats polyfill??
Polyester fiber. Basically pillow stuffing. There are higher end materials, but it's extremely unlikely that you will hear a difference. You can get it at Wal*Mart, Kmart, or any craft place for cheap.
The wireing will depend on the size of the amp used.
Old Aug 10, 2002 | 09:32 AM
The amp used is 800 watts...200 watts rms per sub...at 4 ohm...
Old Aug 10, 2002 | 09:42 AM
jmax
Okay, I remember reading that. The link indicates 120 amps of fusing. The wire should be able to deliver the current without voltage drop / heat. In that case you should use 2 gauge if the wire is less than 13 feet total from battery to amp. Larger wire if any longer, or for less voltage drop.
Old Aug 10, 2002 | 09:46 AM
jmax
Sorry, now I remembered if you are running it 4 ohms stereo and don't push too hard the current requirement should be much less. You may be able to get away with 4 gauge. But I always like to prepare for the future and possible problems. So I would still use at least the 2 gauge.
Old Aug 10, 2002 | 08:42 PM
MIXXMAX's Avatar
Ahhhh...that's what I do for a living. I work with all kinds of wood, plexi-glass, laminate, flooring, etc. I'm sorry, but I wish you lived close by or near the area, and I would have built you one for a reasonable price. Shipping is definitely an issue. It's just too darn heavy. And, I do make good, quality boxes, because they are all made out of 3/4 high density MDF. Plus, all the cuts are machined cut and routed on high quality CNC machines. In fact, I made a few with plexi-glass "see-through" windows and all plexi-glass boxes. Shape of box is no problem, either. Again, sorry, I only do locals. But, if your willing to pay for shipping, I can see what I can do?
Old Aug 10, 2002 | 11:46 PM
Pearl96Max's Avatar
Re: Re: Does Anyone build boxes?
Just to clarify.....MDF..is still Medium Density Fiberboard correct?
--Don
Old Aug 11, 2002 | 01:12 AM
jmax
Re: Re: Re: Does Anyone build boxes?
--Don
You beat me to it! Yes, high density would be HDF. But higher density doesn't indicate that it is any better for speaker boxes, only more expensive to ship. Composite and or baltic birch are the way to maximize sq and reduce shipping charges. They just cost 3 times as much for materials instead.
Old Aug 11, 2002 | 06:14 AM
Pearl96Max's Avatar
Re: Re: Re: Re: Does Anyone build boxes?
I had to say something about that right away. I mean his statement was High density MDF. I was like . The only other thing that I have used was Ultralight, but only for weight purposes.
--Don
Old Aug 11, 2002 | 07:58 AM
jmax
HDF is a real material. From what I remember it is fairly expensive. But other than it's difficulty to move, lack of desire to vibrate because of it's high mass it is basically no better than MDF, for speaker enclosures. The added weight makes it a no-go for in car use.
Old Aug 11, 2002 | 08:02 AM
Pearl96Max's Avatar
O I do agree that HDF exists, but he said basically HDF MDF. I mean its either one or the other.
--Don
Old Aug 11, 2002 | 07:47 PM
MIXXMAX's Avatar
Yes, that's what I meant---MDF (medium density). I was practically falling asleep when I posted. In fact, my job doesn't even deal with high density wood. Not a lot of people use it. Yes, thank you for bringing this to my attention! Sorry, if I confused everyone!
Old Aug 11, 2002 | 09:05 PM
Pearl96Max's Avatar
Not a prob at all. I justed wanted to clarify.
--Don
Old Aug 13, 2002 | 07:35 AM
dpodolski's Avatar
800 Watts definately needs 4 AUG. Also, do yourself a favor and download blaubox. You can still find it on the net and it makes box building that much easier.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
