Need an answer by the morning!
Old Aug 11, 2002 | 07:00 PM
ThumpinMaxima's Avatar
My friend has 2 10" subs in a box...he has a 2 channel amp...the subs are rated at 4 ohms...200watts...and 4 ohms this amp gives 200watts rms...how do i wire the subs into the amp...and how do i wire the subs in the box...cause they arnt in the box yet...the box has the black and red terminal for the speaker wire to go from the box to the amp...now i need to know how to wire the subs AND how to wire the subs from the amp...the amp has a L+ L- R+ R-...plz help me...i need both subs at 4 ohms..!!!!
Old Aug 11, 2002 | 07:15 PM
max'n out's Avatar
mono or stereo? Dvc or svc
Old Aug 11, 2002 | 07:17 PM
chinaonnitrous1's Avatar
Re: Need an answer by the morning!
IF..the amplfier is 4 ohm stable in MONO..you can tie both SINGLE VOICE COIL subs togeter in series to produce a single 8 ohm load..and you can use the amp in MONO to achive a good setup.
Old Aug 11, 2002 | 08:58 PM
AHH i donno here is a link to the amp!!!
http://www.sounddomain.com/sku/ULTDT2800
just tell me what i gotta do to get 4 ohms on both subs...the subs are 2 10 " xtant z series...200watts rms each
Old Aug 11, 2002 | 09:11 PM
hmm....in that case..to get the most performance IF each subwoofer is a 4ohm sub. On the box RED=Positive Black=negative. simple enough just wire them into the box..on the terminals outside...what you wanna do...since you now have 4 spots for speaker wire they'll look like this
connect ONE postive terminal into the NEGATIVE terminal on the other speaker. You will have two open terminals left a POSTIVE terminal on one speaker..a NEGATIVE on the other speaker. You have now created an 8 OHM Load. Now Take the remaining speaker terminals..use them as your POSITIVE (+) and your NEGATIVE (-) to the amplifier. On the amp you also have 4 terminals Refer to your manual on how to install 1 speaker onto your 2 channel amp. You will only use 2 terminals on your amplfier. You will use One positive .... and One negative. (one terminal on channel 1 and the other terminal on channel 2). That will create more than enough power since your amp is bridged.
Old Aug 11, 2002 | 10:16 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Very nicely detailed....Now what if he does have DVCs??
--Don
BTW ...heres another thread to keep up with, Im such a *****
Old Aug 11, 2002 | 10:19 PM
--Don
well then...he better post before i go to sleep...i havent slept in a day or so..so im getting sleepy..ahahahh
Old Aug 11, 2002 | 10:21 PM
Pearl96Max's Avatar
Either he actually has a life, or just doesnt post as fast as we do.
--Don
Old Aug 11, 2002 | 10:24 PM
--Don
he probably accidentally crimped his fingers together...
Old Aug 11, 2002 | 10:26 PM
Pearl96Max's Avatar
--Don
Old Aug 11, 2002 | 10:29 PM
Old Aug 12, 2002 | 05:42 AM
whats dvc?
Old Aug 12, 2002 | 05:47 AM
ok I think I understand...so INSIDE the box...when wiring the subs, i take a positive from one sub, go to the negative on the other...then I use the other negative and positive for the black and red terminal on the box...now on the amp...I am still a little confused on how to wire this...if its bridged i just wire it into the bridged screws...because there are 2 holes which connect with a line and say 'bridged' i wish i could take pictures :-P
Old Aug 12, 2002 | 07:25 AM
Pearl96Max's Avatar
That is correct. You connect the + and - from the box to that + and - on the amp.
--Don
Old Aug 12, 2002 | 10:50 AM
max'n out's Avatar
whats dvc?
Dual Voice coil
VS
Single voice coil
am i the only one that has a bad feeling on this?
Old Aug 12, 2002 | 10:53 AM
*boom*
Old Aug 12, 2002 | 10:55 AM
Pearl96Max's Avatar
--Don
Old Aug 12, 2002 | 07:47 PM
I DID IT!!!! my first INSTALL!!! wooo!!!!! thanks for all the help guys! it sounds awesome, we cruised around in it all nite, those 2 10 inch Xtants hit HARD!!!!!!!
Old Aug 13, 2002 | 06:47 AM
Pearl96Max's Avatar
Go you !
--Don
Old Aug 13, 2002 | 07:35 AM
Redmax's Avatar
Redlinemax Owner
Congrats
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
