amp install
Old Aug 17, 2002 | 04:57 PM
pootsie's Avatar
amp install
Does anyone know if there is an existing opening in the firewall to run
power cables to the battery or if drilling will be required? I believe I
could drill through the space where the clutch would be in a manual shift.
I was quoted $300 by a local installer for a an install on two amps and a
head unit, so I am trying to do this myself.
Old Aug 17, 2002 | 05:14 PM
kyllr's Avatar
Re: amp install
there is an opening close to the upper driver side just remove the rubber cover and you can get the wires through there.
Old Aug 17, 2002 | 05:35 PM
Type97GXE's Avatar
Re: amp install
There is a hole behind the accelerator pedal. Its behind it and up to the right a bit.Its a ***** to get it through there though.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
