Sealed or ported?
Old Aug 29, 2002 | 05:37 AM
nstymax93's Avatar
Sealed or ported?
I have 2 JL 10w1-8 (they are the 8 ohm speakers) speakers and i have a sealed box that they are in but i went to JL Audio web site (note that i dont know everything about audio ) and got the specs and closer info. and was wondering if it would sound better ported? Also it says i should wire them parallel, will that sound better?
-Mike
Old Aug 29, 2002 | 12:58 PM
nismo240sx's Avatar
properly built, they should sound almost identical, except for the fact that the ported box will throw down better
eric
Old Aug 29, 2002 | 02:33 PM
max'n out's Avatar
NOt uless you have alot of knowledge and abiltiy to tune and do some wave calcs
Old Aug 29, 2002 | 09:13 PM
nismo240sx's Avatar
i was assuming proper build/design.
eric
Old Aug 31, 2002 | 12:41 PM
MaxPower2K2's Avatar
i have a 15" l7 solo baric
and i have ports , it gives louder bass with ports
but without ports the bass is more cleaner and defined
and tight
i regret porting my box
Old Sep 1, 2002 | 05:35 PM
nismo240sx's Avatar
and tight
from the looks of it, your ports are WAY too small for the 15L7. i think my friend had about 90 in2 of port, and yours looks like its about 1/2 that much. you might consider making the ports bigger, and that might take care of you.
eric
Old Sep 1, 2002 | 08:33 PM
Mikesburn's Avatar
I like ported for a tighter bass
Old Sep 2, 2002 | 05:05 AM
d_warner's Avatar
Old Timer
I happen to have 2 10W1-8's in my 2001 SE. I used the air-space specs - not actual box dimmension specs in my custom made enclosure. The box I made looks like it is a single enclosure, but it is dual chambered, and essentially each sub is in its own box. Since this is the case, I run a 4 channel amp to them and I have it bridged to a 2 channel set up. You can check out the pics on my web page http . I know the pics are crummy, but what do you expect from a crummy Wal_Mart digital. If you come up with any questions, let me know. I'll be more than happy to try to help.
Old Sep 2, 2002 | 07:43 AM
Unibomber's Avatar
eric
i told him that already + his ports are facing up there hitting the trunk after like 2" of space...i have a 12"L7 and my port is like a foot and a half long and 3 inches wide = rectangular port
Old Sep 2, 2002 | 07:46 AM
Unibomber's Avatar
as for the original ? it all depends on the music u listen to. i like ported because the bass is lower. Sealed the bass hits harder and cleaner
James92SE
142
Jan 2, 2024 09:23 AM
mpbclutch33
Dec 26, 2015 11:11 AM
JonBlz
Oct 5, 2015 06:02 PM
The Wizard
24
Oct 1, 2015 08:47 PM
vrajesh123
Sep 22, 2015 04:20 AM
