cd won't eject dammit!
Old Sep 8, 2002 | 07:38 PM
mddecker's Avatar
So I have the bose cd/radio/tape deck in my '96 se, and I can't get the cd to eject. When I turn it from radio to cd it just says "cd err." Any ideas as to getting this cd out?
Old Sep 8, 2002 | 07:54 PM
96shogunmax's Avatar
Re: cd won't eject dammit!
got one ill sell you. if you want. 96 BOSE perfect shape. just let me know. thanks
Old Sep 8, 2002 | 09:37 PM
spiff56747's Avatar
Have u tried turning the power to the Bose stereo off and then back on? I think this happened to me before, and when i turned it off and then back on, the cd ejected normally.
Old Sep 8, 2002 | 11:28 PM
nismo240sx's Avatar
take the deck apart...its kinda fun to see all the innards. i actually fixed a friends alpine that way. it wouldnt take cd's in, so i took it apart, and put it back together...still didnt work. did it again, and it worked perfectly. probably is still workin in the bastards car that stole it.
eric
Old Sep 9, 2002 | 01:08 AM
jay_johnson's Avatar
I have a solution that works for me, but I can't really recommend it to you because it probably isn't all that great of an idea. If you smack the hell out of the front of the cd player with the butt of your hand, it will usually spit it right out. If that doesnt work, just take your dash off and slap the cd player on the ***... that always works.
Remember, I didnt tell you to do that... just said it worked for me
Old Sep 9, 2002 | 08:16 AM
yu241229's Avatar
For sure fix
1. disconnect the conections to the stereo (power and audio wires) and when you connect it it resets the headunit. if you do not know how disconnect the battery with the headunit on.
2. take it apart
Try both of these things for sure to work. if the first does not work then that means the cd section is faulty and needs to be replaced, or repaired.
Old Sep 11, 2002 | 10:03 AM
DougsfastZ's Avatar
All Black Max
The fix for this is to disconnect both heavy terminals on the power lead of the battery. This will reset the HU and eject the CD.
Doug D
Old Sep 12, 2002 | 07:27 AM
d_warner's Avatar
Old Timer
SLEDGEHAMMER
Old Sep 12, 2002 | 09:04 PM
mddecker's Avatar
sledgehammer
thanks all for your help, especially the physical abuse ideas.
Old Sep 13, 2002 | 08:07 PM
95bluse's Avatar
Doug D
What's the difference between this method & only removing the negative terminal which is much easier? I'd love to know!
Old Sep 16, 2002 | 12:07 PM
JacksMax's Avatar
The difference is this:
People who understand basic electronics and circuits remove only ONE terminal, and those that don't remove both!
Old Sep 18, 2002 | 11:30 AM
Eric L.'s Avatar
On some CD decks, there is a procedure for "forced eject" if the CD gets stuck and the normal eject doesn't work. On my old JVC deck, it happened once, and the fix was to hold the eject button for over two seconds, and it will literally shoot out the disc. Probably not the same procedure for the BOSE deck, but something similar probably exists.
Old Sep 18, 2002 | 11:40 AM
JacksMax's Avatar
I believe the BOSE method is to remove the whole CD player, send it to BOSE, pay like $200 and then reinstall.
Repeat as needed...
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
