Wiring up amps
Old Sep 9, 2002 | 07:46 AM
KillaBee's Avatar
Wiring up amps
I want to connect 2 amps together....I need some help, a link or some tech help.....
I'm trying to connect 2 amps together....what should I put into consideration involving capacitors, proper wiring, and proper RCA cables, and making sure the amps get enough juice....any help will do, thanx
Old Sep 9, 2002 | 05:31 PM
mpc578's Avatar
How do you mean two amps together?? Like one for interior speakers and one for sub?
Old Sep 10, 2002 | 07:26 AM
KillaBee's Avatar
no, not like that, I meant connecting 2 amps to pump the subs that I have. I already have one amp for the interior speakers, and one amp for the subs, but I'm changing my subs and I'm connecting 2 amps to pump my new subs. I know that the 2 amps have to be the same, but power wise, HOw can I do this. I know how to connect them with the RCA jack active pass thru, but what else do I have to put into consideration...thanx
Old Sep 10, 2002 | 06:37 PM
mpc578's Avatar
As far as power wise, run some heavy gauge wire (2-4 depending on total power) and run it to a distribution block in the trunk area. Then run some 8 gauge off the block to each of the amps for the power. Run seperate ground wires, although they can be ground the same place (ie the same seat belt bolt) and just tap into the remote wire to get your extra remote lead. As far as the capacitor goes, there are a couople of experts on here (pearl96max..don) who would know better than I.
Old Sep 11, 2002 | 06:23 AM
MIXXMAX's Avatar
Are you talking about bridging ("daisy-chaining") the two amps together? If so, the simplest way to do this and for your signal to sound more "clean" (less noise) is that the amps must have a set of RCA "pre-out" jacks, as well as the input jacks. Here, you run an input signal in one amp, and then "pre-out" (from the same amp) to the input signal of the other amp. If your looking for more power to power your subs, your probalbly better off installing two subs (running mono--1 channel) for each sub/channel. Here, you have more power for each sub with their own amplification.
Old Sep 11, 2002 | 05:52 PM
jmax
I don't know if I am more confused by the question , the responses, or th eimmort I am drinking, burb, I mean immort.
But as one person said do you intend to truly daisy chain or do you just want a seperate amp for each sub? Or do you want one large monoblock for both subs? With a true daisy chain configuration the amp outputs bridge. The above post was not about this type of daisy chain but simply runnning RCA outs to another amps RCA ins. There are not many amps that can daisy chain, and the number fo people who have the need is likewise few.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
