best amp
Old Sep 26, 2002 | 09:48 AM
altima's Avatar
best amp
Hi, this is my first post I'v started to upgrade the system in my car..and i want to know the best amp to power my infinity kappa perfect 12.1 rms:350w, frequency response: 18~150, nominal impendance: 4ohms. I know it's better to over power than to underpower, but other than that im dumb about this stuff. thanks guys
Old Sep 27, 2002 | 01:55 PM
time2reup's Avatar
Re: best amp
Everybody will have their own opinions, but basically when it comes to amps you get what you pay for. Main thing to do is get your RMS at the right level, and make sure the amp is stable at the load you are going to give it. I like the older Kicker ZR amps...I have 2 both are rated at 240w but are actually 356 and 389 on the birth records....try searching, everybody has some favorite brand
Old Sep 27, 2002 | 02:14 PM
LeonBlackMax's Avatar
If i were you i'd get a punch360. It should power that sub perfectly.
Old Sep 27, 2002 | 02:48 PM
Gates's Avatar
Re: best amp
There really isn't any "best" amp out there. There are a lot of really good amps you can get. If you want to save some money, look at a JBL 600.1. This amp will give you over 300 watts at 4 ohms for less than $200. Make sure that you look at your amp's rating at 4 ohms and not 2 ohms or you'll be underpowering your sub.
Old Sep 28, 2002 | 06:28 PM
BLack2k2MaX's Avatar
go for the rockford 500s amp that should work well
Old Sep 29, 2002 | 08:24 PM
Amendemula's Avatar
Re: best amp
i have the same subs
i've had it forever!
i love my subs
now.... that we got that part over with
at first i ran the subs off of a rockford fosgate 250a2 (old version)
then i switched it to rockford fosgate 400a4 (old version)
i heard the old versions are better thats why i keep the old versions
i just blew that amp (i think)i got to go get it checked out tomorrow
if it is broken then im probably get a rockford fosgate 500a2 or if they ahve one thats even better
try to get your rms high thats my goal now... soo i can make the bass really loud and low from the controls of the amp
but both the previous amps are realllllllly good they hit hard
anand
Old Oct 1, 2002 | 11:35 AM
dat_nomad's Avatar
Re: Re: best amp
DITTO !!!!!!!!!
PPI Thats my favorite this month.
Old Oct 2, 2002 | 11:35 AM
wyskibumm's Avatar
Re: Re: best amp
Jl Audio amps are really good-high end. You're using some high-end subs, why not juice them up with some clean powerful amp? the 300/4 is gunna run you anywhere from 400-500 but its totally worth it. It will rattle your nut$ack.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
