Best way to run amp power cable on 3rd gen
Old 10-01-2002, 08:30 PM
tafan321's Avatar
i have a 90 maxima and am going to install some subs but i'm not sure the best way to run the power cable to the amp? any suggestions?
Also where can i get a new power antenna for a reasonable price?
tafan321 is offline
Old 10-02-2002, 11:37 AM
wyskibumm's Avatar
Re: Best way to run amp power cable on 3rd gen
I ran my cable right below the steering column and to the left a little bit. I have a 91 SE, and, then i ran it back under my seatbelts and stuff. Its not a bad job at all. Just dont be lazy and run your signals on the same side as your power. I can make some measurements as to exactly where i drilled my whole. Also make sure you patch the hole up with some silicon putty.
wyskibumm is offline
vybz05
12-10-2015 07:38 PM
Finkle
09-27-2015 09:53 PM
homeyclaus
09-03-2015 06:15 PM
ViciousVQ30
08-05-2015 05:40 PM
Quick Reply: Best way to run amp power cable on 3rd gen
