Need Help Wiring Amp
Old Oct 14, 2002 | 08:55 PM
ignentchoker's Avatar
Hey all, I already tried a search on this but only got information about various ways to run power wire to trunk through firewall. My question is how tough is it to run RCA cables to the trunk to hook up to the amp. I havent taken anything apart yet or tried to hook them up, but I am planning on doing it pretty soon. I would jsut like to get suggestion about the best way to run both power cable and RCA cables to the trunk.
Old Oct 14, 2002 | 09:26 PM
max'n out's Avatar
Pull the head unit, plug the rcas in...run um back under the carpet through the trunk. Dont' forget remote too...Power through the firewall under the carpet...Don't forget fuses.
Old Oct 14, 2002 | 10:33 PM
DMAN11's Avatar
Re: Need Help Wiring Amp
Well choker, I agree with everything Jayson said above, but here's a little more detail.
It's not too hard, and shouldn't take you too long. I would suggest first of all, that you run the RCA's on one side (maybe passenger), and power on the other side (driver side, since battery is on this side). This will help keep out the engine noises right off the bat. You can pull all the plastic trim from front to back. There are the little kick panels in front, then the strip along the doors, front and back. You can undo the sections of plastic between front door and back door too for access along the floor. When you get to the back, you can pull under the back seat for total hiding, or lay along the cracks if you choose. Once you pull off the plastic strips and stuff, you will be able to run all wires under the carpet, then put all plastic back together. Remember where you takeany loose clamps from, and you shouldn't have any problems. Good Luck!!,,,,,,DMAN
Old Oct 14, 2002 | 10:42 PM
Maxima Dan's Avatar
Just a word of caution. Since the weather is starting to get a bit colder the little plastic parts will begin to get brittle. You should try and make sure your car isn't too cold before you start pulling everyting up. If you break it it will rattle and drive you nuts.
Old Oct 22, 2002 | 07:03 PM
coryf's Avatar
rca hookup
is there an adapter to plug into the stock harness for my rcas? i dont really wanna splice my stock harness and slide in the "best buy special" thanks for any help.
Old Oct 23, 2002 | 08:39 AM
studman's Avatar
Check out PAC's website. They have a couple of products for our cars.
http://www.go2pac.com/
Go to the products section, and search by make and model.
I have the AOEM-NIS2 adapter and it works fine. No wire cutting/tapping required.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
