Wow!!!! Amps!!!
Old Oct 25, 2002 | 01:12 PM
InfamousOrange's Avatar
Wow!!!! Amps!!!
wow amps are confusing. i have a quick question about amps for components. how many channels do i need to power 4 in car speakers not including sub? that means front set and rear set. should i get 2 or 4 channel? should i get 1 amp per set? and wat are the best brands for sq in these areas? thanks for all the help.
Old Oct 25, 2002 | 01:34 PM
releasedtruth's Avatar
rilla dope
If you want them all run on amp power, you'll need a 4 channel to have any fade control. You can also run a 4 channel mixed to power a sub on 2 channels and the 4 components off the other 2 channels of the amp.
I would go with a nice 4 channel amp matched to the quality of your components or coaxs
Old Oct 26, 2002 | 12:31 AM
nismo240sx's Avatar
if youre doing all 4, PLUS a sub, i suggest a 4 channel + 2 or 1 channel...or a 5 channel.
eric
Old Oct 26, 2002 | 08:10 AM
skeelo34's Avatar
Preferably buy a 4 channel amp, but if you can get a great deal on a 2 channel, buy it. If you have some high end head unit with special dsp or wahtever, get a 4 channel one.
Old Oct 26, 2002 | 08:43 AM
max'n out's Avatar
It depends if you have seperates or coax'. And passive x overs or active.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
