Basslink auto turn-on question
Old Oct 26, 2002 | 12:24 AM
Speebs's Avatar
I aim to misbehave.
I'm thinking about getting a Basslink, and am trying to plan out the installation. How does the auto turn-on feature work? I plan to use the pre-amp output from my aftermarket HU to send the signal to the Basslink instead of using the speaker-level input of the BL. Is it possible to use the auto turn-on with the line-level inputs? Or am I going to have to switch the unit on every time I want to use it (or wire it to go on with the HU)?
Thanks,
Doug
Old Oct 26, 2002 | 09:06 AM
ThurzNite's Avatar
i'm pretty sure it senses a signal from the rca or line-in and turns itself on. i remember that installation was rediculously simple.
Jae
Old Oct 26, 2002 | 06:13 PM
BlackMax2k1's Avatar
If using the speaker-level inputs, an audio-sense circuit will turn on the amplifier whenever a signal is present. If the RCAs are used, a 12-volt, remote-turn-on lead is required. The system has barrier strip connections for power, ground and remote turn-on.
9aj9
Apr 5, 2020 12:11 AM
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
