Building a false floor for the trunk
Old Oct 30, 2002 | 06:20 PM
1MAX2NV's Avatar
Is it possible to build it in one big piece that will cover one end to the other? Or it's only feasible if it's cut into 2 or maybe even 3 pieces?
Old Oct 30, 2002 | 06:37 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Building a false floor for the trunk
Itll work in one piece....just kinda gotta work it in there...
--Don
Old Oct 30, 2002 | 11:36 PM
DMAN11's Avatar
I agree with Don, I got mine in in one piece, except for a door cut out for access to the spare tire...hehe Just pull out the carpet that's on the floor of the trunk, flip it over on a sheet of playwood, MDF, or whatever you use, and trace it as a pattern. Cut outside the lines in order to leave it a little bigger than the carpet, cause you can always trim some off if it's big,,,,but you can't put some on if it's small. That's what I did, and it fit perfect...
DMAN
Old Nov 1, 2002 | 09:28 AM
1MAX2NV's Avatar
Thanks guys. I'll show some pics when I'm done. I'm going to mount the amp in the spare tire hole. Build a flase floor with a window to show of the amp. Wire up some neons. Maybe finish it up by building some bondo/fiberglass trim plate. Where is a good place to order high quality carpet to cover the flase floor?
Old Nov 1, 2002 | 04:57 PM
releasedtruth's Avatar
rilla dope
Mine is 3 pieces. Looks damn good, near perfect stealth. Much easier to take out that way too at least from my perspective. Take a look see.
http://www.selfactualized.com/seats/trunkoff.jpg
Hard to tell it's 3 pieces, I love it. I also have amp covers for complete stealth. After all, Ghost Rider is the perfect stealth car..... Like KITT and what not
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
