what's most clean way to run wires from trunk to the front? need ure ideas!
Old Nov 8, 2002 | 03:28 PM
nadir_s's Avatar
vicodin ... gift of life
hey guys
I need to connect some wires that are gonna be from the trunk all the way up to the center dash panel...
I was lookin at the car and I wasn't sure how to do it... cut up the carpet?? run it under wha??? no clue guys! I searched but I'm not picking the right set of words to find what i'm lookin for. Help me w/ some ideas on how to do it and how you guys did it when u wired in an amp or something. Thanks!
Old Nov 8, 2002 | 05:54 PM
MIXXMAX's Avatar
Re: what's most clean way to run wires from trunk to the front? need ure ideas!
Originally posted by nadir_s
hey guys
It all depends what kind of wiring you're using it for. Is it for a stereo system? If so, run the battery power on the same side of battery (driver's side) and run the signal cables/wires on the opposite side (passenger's side). To do this, just lift up on the door sills (step panels) from each door. Here, you can see where all the factory wiring is running. Just follow the track and run the wire(s) along with the factory wiring. I found it easier also to remove the "bottom" part of the rear seat to feed the wire through the trunk. Good luck!
Old Nov 8, 2002 | 06:29 PM
nadir_s's Avatar
Re: Re: what's most clean way to run wires from trunk to the front? need ure ideas!
thanks! now i'm stuck at gettin into the engine bay... ******* firewall. Where should i drill??
Old Nov 8, 2002 | 06:41 PM
MIXXMAX's Avatar
There should already be a spot/opening above the driver's kick panel. It's almost like a "blank spot" where this should be a hole. Drill here and make sure you install a rubber grommet around the inside of the whole so that the wire doesn't rip/rub/or tear along the sharp edges. Also, make sure both sides are clear from drilling into anything.
Old Nov 8, 2002 | 06:44 PM
TylerBorg's Avatar
well i have a 4th gen and if you look at my member page on sounddomain you can see where i found an exisiting hole that fit 4awg power wire.... had to take out a rubber piece, but that took .5 seconds
if you want to drill a smaller hole underneath the driver's dash there is a piece of rubber, you can see that there is a diamond print around it, ill try to get pics if u dont see what im saying.
well anyway, if you take that piece off then you have one piece of metal access to the engine bay, thats where my 8awg wire runs
Old Nov 9, 2002 | 05:39 AM
nadir_s's Avatar
Thanks guys! I ended up wiring the 12 wires through the grommets in the firewall (hood latch cable). Everything worked out good!
My in-car PC is just about d one
vanebecker
Aug 19, 2015 09:45 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
follyburr
Aug 7, 2015 09:50 PM
