Multiple Line Output Converters
Old Nov 11, 2002 | 06:30 AM
TallB'00SE's Avatar
Is it neccessary to have more than one line output converter. I'm currently planning on hooking up my 5-Channel Alpine V12 amp to my 5th Gen Non-Bose HU. I was concerned that if I play CD's that divide different sound front to back but I only have my Amp amplifying sound from the rear speaker outputs, that I would lose the sound sent to the factory front speaker outputs. Would hooking up 2 line output converters solve this problem, or would this be redundant. I also just bought one line out put converter. It has 5 wires. Four of these wires are obviously the speaker wires, but I don't know what the fourth is. Is this a power wire to help "pre-amp" the signal, or is this a ground wire? Any help and/or advise is appreciated.
Old Nov 11, 2002 | 08:30 AM
2MuchMAX4U's Avatar
Re: Multiple Line Output Converters
Your amp has two sets of RCA inputs right (4 plugs)? And your 1 line output converter has 2 RCA outputs right(2 plugs)? I sugguest you go buy another line output converter and use one for the front and one for the rear. That's what I did. Good luck!
Old Nov 12, 2002 | 05:12 AM
TallB'00SE's Avatar
I am still trying to find out what the 5th speaker-type wire coming out of my line level converter is. I understand the four wires to tap into the speaker wires, and I understand the RCA outs to go to my amp. However, I'm still confused what the fifth wire is. Power, Ground, Remote Power, etc.? Any help is appreciated.
Old Feb 13, 2003 | 12:20 PM
MaxJag's Avatar
Re: Line Output Converters
It is a ground wire. What model adapter do you have?
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
