Amp rack with fans
Old Nov 13, 2002 | 04:07 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Amp rack with fans
I was thinking about doing an AMP rack with a plexi glass top.. I have 2 amps side by side..
I was going to have 2 fans on 1 side and the other 2 on the other side..
which is better....
the 2 fans on the left sucking air, and the 2 on the right blowing air ( thus having a constant draft )?
or the have all four fans blowing air into the amp rack?
I thought I read some where that #1 is not as effective due to space size and heat and the amount of air smaller fans can move...
But I can't find it anywhere and I might have been drinking that night
thanks
Old Nov 13, 2002 | 04:40 PM
ny96max's Avatar
have them set up where 1-2 pushed air through and the other 1-2 pull air out. Otherwise they would cancel each other out facing the same way!
Ant
Old Nov 13, 2002 | 07:40 PM
bahmax's Avatar
I think the constant draft method would be much more effective. I do not understand your reasoning why it would not be. This is how computer cooling systems, etc. work
Brett
Old Nov 13, 2002 | 07:48 PM
Bags's Avatar
well ike I said I "thought" I read that.. I guess I waas wrong.. that's why I asked.
Thanks for the input
Old Nov 13, 2002 | 07:55 PM
GundamWZero's Avatar
The first method is right on to keep constant flow, but don't you have enough trunk space to circulate air without fans? To have your amps an a plexi-glass rack would elevate your amps, thus allowing air to travel above and below your amps. Unless you are planning to mount you amps vertically, along your rear seats facing the cabin, then yeah you'll definitly need those fans. I got a pic of mines mounted verticaly, along the rear seats facing the cabin, but I don't know how to post pictures in these forums. I am not using any cooling fan either.
Old Nov 13, 2002 | 09:00 PM
max'n out's Avatar
What you wanna go with is a push pull idea...One to pull cool air in and one to push the other out of the rack. Make sure you have a place for the air to go then...Many have put true cooling systems in ...Bascally a/c for the amps.
Old Nov 13, 2002 | 09:08 PM
Conrad283's Avatar
I need a truck
i like that idea ... where would you vent it too ... out of the car of just the trunk
Old Nov 13, 2002 | 09:12 PM
max'n out's Avatar
Depends...Somtime just out of say the tire well, or side panel via a one way vent. Takes some work though. The a/c thing works just like the a/c in your car just on it's own system.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
