5/8 inch particle board
while at the home depot i was looking at marterial to build my trunk with. i picked it the MDF board, and it was really heavy. Then i saw 5/8 inch particle board. Can i use this?
Originally posted by victor
if your not going to use MDF, then use a good high quality plywood (like birch). particle board is a no no.
yeah, even if.
what kind of sub are you going to go with?? MDF is really heavy, but that's because it's really dense, which makes it stiff. with a sub box you don't want any flexing of the sides. i guess you can use particle board if you really want, but you'll have to brace it a lot.
also, with particle board, make sure it does not get wet, or it will fall apart.
let me know what kind of sub.
what kind of sub are you going to go with?? MDF is really heavy, but that's because it's really dense, which makes it stiff. with a sub box you don't want any flexing of the sides. i guess you can use particle board if you really want, but you'll have to brace it a lot.also, with particle board, make sure it does not get wet, or it will fall apart.
yeah, even if.
yeah, even if.
And you gotta love the wood smell after it's al done. Mine smelled like a forest for 3 weeks after my trunk was done. Now it smells like leather, much better. My trunk is made of mdf, not as thick as the parts of the box that're wood, but it works nice
oh, my fault. didn't quite pick that up when i read your post.
but yeah, particle board is fine, if you put a seal on it. otherwise, like they said particle board will swell and fall apart. go with some plywood. MDF is not necessary.
Originally posted by killer2002SE
particle board & plywood will bend after a while and will look cheap,
i would suggest thinner MDF, maybe 1/4 inch? should be strong enough for simple weight...
The other key to stiff parts like boards is the braceing technique.
