which is better optima or stinger battery? Need help headlights are dim
my headlights dim when i him my brakes and when my compressor for my airbags comes on....and when my stereo is on.....do i need an optima yellow top or would a stinger yellow top be better?
or is something wrong with my car that would cause the lights to dim.
thanks for the help
thanks for the help
Originally posted by ejj
You sure its your battery and not your alternator?
but if you wanna know which is better, check out the reviews @ www.carsound.com
p.s. OPTIMA
i was told the Optima puts out the same amount of power as other batteries much cheaper...
only thing is, the Optima holds it's charge a lot longer and charges up faster..
say i dont need to play the stereo with the car off and dont plan on it... do i need to waste an extra 60-80$ on an Optima.
Originally posted by TL@altimas.net
if you have a system you don't want a red top anyway..
-Cyrus
False.. read Optima's FAQ.. all the answers are right there..
14. When should I consider a deep cycle?
Any time you need the battery to supply all the operating power for a vehicle or other device. Additionally, deep cycle batteries should be used in vehicles that have heavy accessory loads where the alternator cannot maintain the battery in a fully charged condition.
17. When should I use a Deep Cycle OPTIMA as a Starting battery?
"Deep Cycle" batteries are designed for applications that require deep, repetitive amperage drain, like trolling motors, golf carts, and electric wheelchairs, or RV house power sources. However, there are other applications, called "Heavy Cycling" or "High Cycling", when a Deep Cycle OPTIMA can successfully replace a starting battery to provide longer life and better performance.
In heavy cycling or high cycling applications, a vehicle will pull unusually high amperage levels from the starting battery due to extra accessories or limited alternator capacity. Public safety professionals, such as police, fire, and ambulance fleet managers often find that traditional starting batteries cannot provide adequate life and performance due to heavy cycling. This is an excellent opportunity to provide your customer with longer life and better performance by using an OPTIMA Deep Cycle battery in this type of application.
In any vehicle or equipment that will use the battery only for Starting, Lighting, & Ignition requirements and has a properly working alternator, the OPTIMA Red Top Starting Battery will perform extremely well, often providing up to two to three times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice.
Car Audio:
Yellow Top/Deep Cycle onlyRed Top/SLI will not be covered by warranty
doctorpullit
10-28-2019 10:58 PM
bigfrank
10-01-2015 12:51 PM
