Firewall
Old Nov 26, 2002 | 07:13 PM
mAXZPEEd's Avatar
Firewall
What is the best way to get into the firewall on a Max 02? I am trying to install my amp...Also do I need any special adapter for installing the amp for a stock Max 02 head unit? thanks all
Old Nov 26, 2002 | 10:33 PM
98BlaximaSE's Avatar
Re: Firewall
In most cases for most cars, you would have to drill through it. If you do do that, be careful where you do it. Don't want to drill into something else accidently.
Old Nov 27, 2002 | 05:25 AM
TallB'00SE's Avatar
Drill a small pilot hole first. This will help: A. Guide your larger drill bit through the wall and B. Not be as loud if it is in the wrong place. Also, be sure you use a firewall grommet. This will keep out water and make sure that your wire dosen't eventually get chewed up by the hole it is running through. Good Luck...it is a PITA.
Old Nov 27, 2002 | 10:03 PM
lophix's Avatar
wow!! you actually have to drill??? on the 3rd gens, you go through the grommet by cutting a small hole in the rubber and leading the cable in.
Old Nov 28, 2002 | 06:29 AM
maugs808's Avatar
Pics of running 4 ga wire thru 2K1 firewall
Here's some pics i took from when I ran 4 guage wire thru the firewall of my 2K1 Max. FYI, I have an automatic so I don't know how this will work if you have a stick...
Find diamond shaped piece of firewall liner up under the drivers side dash to the left of the brake pedal. Pull it back to expose the metal of the firewall. Drill a small (3/16") hole thru firewall.
Notice the pilot comes out in the engine side in a location away from anything important.
Continued...
Old Nov 28, 2002 | 06:31 AM
maugs808's Avatar
Pics of running 4 ga wire thru 2K1 firewall (cont'd)
I bought a rubber bushing at my local ACE Hardware for about a buck. I brought a small piece of 4 guage wire with me to make sure it had the right inside diameter to give it a snug (i.e waterproof) fit.
The bushing required a 7/8" hole thru the firewall so I used a 7/8" holesaw.
Almost done...
Continued...
Old Nov 28, 2002 | 06:33 AM
maugs808's Avatar
Popped the bushing in the hole and I was ready to run the wire!
Hope this helps!
Old Nov 28, 2002 | 12:39 PM
mAXZPEEd's Avatar
Awesome! This helps a lot. Thanks....
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
