Din pocket tray on 4th Gen
Old Nov 29, 2002 | 04:10 PM
MAXIN's Avatar
Din tray and kit on 4th gen
Can I mount a regular din-sized pocket tray in place of that little stock pocket tray with the flip door?
Like the ones used as a spacer under single din head unit installations...
Where can I pick one up?
Also, I know you dont need an install kit for the 4th gen if your installing 2 single din units, but I've seen some much cleaner installs then mine, what did you guys use? Did you dremel out the opeining?
Old Nov 29, 2002 | 06:32 PM
MIXXMAX's Avatar
Re: Din tray and kit on 4th gen
If it's a 4th gener, the regular pocket and flip door are a direct fit without any modifications. As far as the headunits, all three spaces in the dash can fit full din size receivers without any problems. Some brands are slightly bigger than the opening, but only by a 1/16" or so. I had to slightly widen my opening to fit my Kenwood receiver and Kenwood full din CD.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
ef9
Sep 29, 2015 11:29 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
