Help with install (running wire)
Old Dec 20, 2002 | 09:44 PM
mretrum's Avatar
I've got a few questions to ask -
Anyone who has run 0 guage wire through a 4th generation max:
Where did you run it?
Where did you get it through the firewall?
Is it difficult to get the front seats out and how do I do that?
Thanks in advance
Mike
Old Dec 20, 2002 | 10:29 PM
nesquiknate's Avatar
i havent run zero guage but to get thru the firewall you need to drill a hole (yes i know it makes you want to cry) i drilled on the side where the battery is . there is a lil circular shaped thing and it goes thru if you look up above your pedals you will see the exact same shape and yes it is ok to drill thru there. if you have any questions let me know and i will go take a pic of what im talking about for you
Old Dec 21, 2002 | 07:43 AM
mretrum's Avatar
I pic would be great
Old Dec 21, 2002 | 10:57 AM
ive got the pics taken but my dad keeps stealing my camera link so as soon as i find him to get the link back i will post pics.
Old Dec 21, 2002 | 11:07 AM
http://maxima.cardomain.com/member_p...=243526&page=3 its the bottom picture ... i circled where the wire goes (its a crappy picture but unhjtil i find that link i cant post the good pic
Old Dec 21, 2002 | 11:08 AM
sorry the link didnt work here http://maxima.cardomain.com/member_p...=243526&page=3
Old Dec 21, 2002 | 11:21 AM
ok i finally got it with good pictures ... sorry for all the bad ones
http://maxima.cardomain.com/member_p...=243526&page=4 let me know if theres any other way i can help
Old Dec 21, 2002 | 04:06 PM
mretrum's Avatar
Great man, thats helps alot, thanks for the help! What guage is that you are running? Where did you run it in the car?
Old Dec 21, 2002 | 06:29 PM
releasedtruth's Avatar
rilla dope
I ran through the firewall too, but dual 4g wires, very nice indeed. May as well have 2 holes I say with some sealant and grommets, works well. Same location in the wall though. Seats take 5 minutes to take out or put in, just some bolts and some clip ins for the power if you need to take them out for any reason
Old Dec 21, 2002 | 08:07 PM
im running 4 guage wire but i didnt take my seats out ... just pulled up the carpet and ran the wire thru the factory white housing along the driver side
Old Dec 21, 2002 | 08:20 PM
SamMan23's Avatar
There's a hole in the firewall to the right of the fuel filter(left if you are looking from the front). It had a black stopper in it, and I just pulled it out. I run two 8 gauge through it, but it seemed wide enough to run 0 if I remember correctly. I tucked it into the side of the console and ran it down the hole in the carpet where the e-brake comes out(had console removed).
The chairs are easy to remove. 4 big bolts. Two in front and two in back under two covers that you can just pull off.
Are you installing amps? in trunk or under seat?
Old Dec 21, 2002 | 08:46 PM
mretrum's Avatar
Amps are going in the trunk, I'm just thinking I'll probably have to remove the seats to run the 0 guage.
Old Dec 21, 2002 | 09:22 PM
mretrum's Avatar
Another thing:
I bought these battery terminals right. There are two smaller holes for wires and then a big allen screw to attach a 0 guage ring terminal too. I took a look at the battery and there are 3 wires going to the positive post, with the addition of my 0 guage for power wire for my system making it 4. My question is: can I twist two of the factory wires together and put them in one slot in the battery terminal and then put the other factory wire in the other slot and then attach my ring terminal to the battery terminal and connect the terminal to the battery post? Would that be ok?
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
