For those w/aftermarket components
Where did you mount your 1" tweeter? The stock position in the a-pillar is way too thin and can't fit the depth of an aftermarket tweeter. I guess I can put it in the door panel next to the door and window locks, but that would require ripping through my leather. The black triangle between the window, door panel, and a-pillar seems too small also. Any other suggestions?
Took the gxe a piller with no tweeter and custom mounted it there, firieing across ina different angle and height.
But most put it in the mirror cover that you refered to, it's simple to do just need a hole saw. You can also custom coax mount it over the mid or refit the stock a piller spot to make it fit.
I have the JL Audio XR650-CSi Components, and my tweeter fit perfectly in the OEM opening. I have a '97 Maxima SE w/ Bose Audio System, and the OEM tweeter is located next to the door handle on the door panel. I even used the OEM grille over the tweeter.
Hope this helps,
-Nick
Hope this helps,
-Nick
Re: For those w/aftermarket components
same here...but mine is in that triangle thing...looks real good
good luck
good luck
Originally posted by adamlee2001GXE
My Focal tweeters fit exactly in the A-Pillar, according to the stereo shop, muhaahahaha. Seems like everone on this board installed their own stuff, not me, I just pay to have it done!
good luck
good luck
RealityCheck
10-02-2015 06:34 PM
