Home Audio Question about Impedance
Old Dec 30, 2002 | 03:40 PM
rc0312's Avatar
Hmm, sorry for posting a "home audio" question when this is mainly a car audio/electronics forum. But, I know you guys can answer this, and I have really no one else to ask. Its a simple question. If I were to buy a center channel speaker that is "6 ohms" but my reciever's RMS is at 8 ohms, what are the losses or issues? Thanks for your replies. (I'm a pure n00b at this, lol, I'm slowly learning)
Old Dec 30, 2002 | 04:07 PM
packetattack's Avatar
Re: Home Audio Question about Impedance
RC,
Its pretty simple. Ohms are a measure of electrical resistance. The higher the OHMs, the MORE resistance the amp will "feel." When the load is decreased, for example, 6 ohms instead of 8, the amplifiers power output will increase, due to their being less resistance to the power coming from the amp.
Most high quality amplifiers can drive loads at lower resitance levels. I am pretty confident that the 6 ohm center channel speaker would cause zero effects on your amp, since I've driven a lot of home theater stuff down to around 4 ohms with no damage.
If you check your amplifer manual, there is usually a MATRIXED chart, showing the different power outputs based on resistance levels.
Old Dec 30, 2002 | 04:24 PM
rc0312's Avatar
Re: Re: Home Audio Question about Impedance
Ah, okay, thanks a lot for your help.
Old Dec 31, 2002 | 08:50 AM
spta97's Avatar
I am running 2 speakers that are 4 ohm on my Onkyo. I can push the amp to the limit, but when I tried it on a Sony the proection circuit came on. Under normal sound levels they will sound great (much louder than 8 ohm speakers) but the quality of your amp will determine how much you can increase the volume.
You should have no problem.
Moral of the story = Sony sucks, Onkyo awesome
Old Dec 31, 2002 | 09:39 AM
Onkyo makes good receivers
I have an Onkyo 200w two channel receiver, nothing fancy that drives two Polk RT16s and a 250w amplifed Polk sub usually at 3/4 output with no issues/clipping etc. I've also driven speakers at 2-6 ohms with no output stage issues, apart from the top getting a little warmer than normal.
Old Dec 31, 2002 | 09:51 AM
spta97's Avatar
Re: Onkyo makes good receivers
I've got the Onkyo TX-DS 777 (110 w x 5 - I think). I've got it located in a rack so that thing gets super hot in the summer when I'm driving it. I've gotta get one of those fans because when I'm really driving it - it will overheat
DJLAX152
May 4, 2021 11:46 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
