Just installed sub/amp. Sound is kind of flat.
Old Dec 30, 2002 | 04:04 PM
BlackMax2k1's Avatar
I don't hear any thumping. I have a JBL300.1 amp and a Kicker VR 10" sub. I know it's not going to wake the neighbors with this setup but I was expecting more. I checked the sub connection to the amp. I checked the sub preouts on the deck. Any suggestions? Anybody have this amp or one similiar?
Old Dec 30, 2002 | 05:00 PM
victor's Avatar
what kind of box do you have?? are you sure you wired the sub and amp correctly?
Old Dec 30, 2002 | 07:22 PM
LeonBlackMax's Avatar
just make sure your wired in parallel and you should be getting full 300 watts from the amp and it s hould sound pretty good. I had 1 VR 12 for a while and i like it, theni got 2 an dlike it even more,
Make sure your sub is firing toward the back of your car also that makes a world of difference.
Old Dec 30, 2002 | 08:39 PM
max'n out's Avatar
Your sure you got power to it? If so, check the gain, make sure it's up 1/2 to 3/4 without cliping.
Old Dec 30, 2002 | 08:50 PM
The green light is on the amp so it's getting power. I'm getting bass but not as much as I would of hoped. The amp has four terminals for speakers -+ and -+ right next to each other. How am I suppose to connect that with the one sub?
Old Dec 30, 2002 | 09:06 PM
max'n out's Avatar
With as low of an ohm load as possible, I forget off my head, the VR comes with either singe or dual vc right? Which do you have?
Old Dec 30, 2002 | 09:16 PM
Yep, I have the dual vc. I hooked that up right from the instructions from Kicker.
Old Dec 30, 2002 | 10:10 PM
max'n out's Avatar
Ok so take the instructions and run it 2 ohm mono...Make sure it's not running 4 ohm stereo, cuz that would be why you are not getting power.
Old Dec 30, 2002 | 10:37 PM
That's what I did. How does it connect to the amp?
Old Dec 31, 2002 | 07:43 AM
quiksand's Avatar
you should bridge it. The negative wire goes one channel on the amp and the positive goes to the other. You may also want to check the bass boost if the amp has one.
Old Dec 31, 2002 | 10:34 AM
max'n out's Avatar
If thats what you did then you know how it is connected to the amp.
Here is how it hsould be: one set of wires one pos, one neg out of the amp from the point where it says 2 ohm mono with a line to a pos and one to the neg out of the amp to the first sub then take it from that sub to the next sub.
Old Dec 31, 2002 | 11:23 AM
This is the thing that confuses me. I have in the past bridged amps that were 2 channel. But this is a 1 channel amp with 4 speaker terminations for 2 seperate subs. I'm assuming I just pick on set of +/- and use it and not hook it up like I'm bridging a 2 channel amp.
Old Dec 31, 2002 | 12:16 PM
MetaOrbit's Avatar
Got Projectors?
Damn, if I had known Image Dynamics had a free-air capable sub I would have bought it. As it is, I just ordered a Kicker Comp 8" a few days ago. It was one of the few subs I could still find that specifies free-air usage.
Old Dec 31, 2002 | 12:45 PM
KLoWnPR109's Avatar
I've got my DVC running on the two outermost terminals if that helps any.
Old Dec 31, 2002 | 12:59 PM
victor's Avatar
think you got the wrong thread...
Old Dec 31, 2002 | 01:24 PM
MetaOrbit's Avatar
Got Projectors?
ROFL...I don't know how the hell that happened...my bad.
Old Dec 31, 2002 | 01:46 PM
Audtatious's Avatar
Bandwagon Lover
If this is a DVC sub, which it seems, connect each coil to one of the speaker outputs ( with 4ohm coils, this should net a 2ohm load ). If you want to run a single cable, you can use either side of the connector and make a "Y" cable out of it with equal lengths instead of running the cable to one coil, then jumping to another coil....
Old Dec 31, 2002 | 02:29 PM
So you have it like this-
with the arrows pointing to the terminals you have
hooked up
Old Dec 31, 2002 | 02:38 PM
Audtatious's Avatar
Bandwagon Lover
hooked up
If it is hooked up that way, it is wrong. See the owners manual, page 4:
http://manuals.harman.com/JBL/CAR/Ow...nual/bp_om.pdf
Old Dec 31, 2002 | 02:45 PM
Right, so it doesn't matter what set of +/- you use cause it's for multiple subs.
Old Dec 31, 2002 | 03:24 PM
KLoWnPR109's Avatar
So if I have the 600.1, how would I wire up a dual 4 ohm DVC sub correctly to get 600 watts?
Old Dec 31, 2002 | 04:51 PM
Audtatious's Avatar
Bandwagon Lover
Coil 1 +/- to one side of the connector and coil 2's +/- to the other side. This will net a 2ohm load to the amp....
Old Dec 31, 2002 | 04:56 PM
I'm using only one set of wires. I wired the sub up parallel.
Old Jan 1, 2003 | 10:55 AM
KLoWnPR109's Avatar
I've got the sub wired up right to get the 2 ohm load.
I'm still confused though. What terminals am I supposed to put the two wires in? There are 2 positive and 2 negative, and none are labeled bridged. Those instructions didn't help me any, as nothing is labeled bridged. Thanks
Old Jan 1, 2003 | 01:05 PM
max'n out's Avatar
THere should be a little line that conects one neg and one pos that says 2 ohm above it, anything like that? Or a switch that says 2 ohm mono? I would think it would have one of the two.
JRod28
Dec 29, 2023 09:56 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
