Amp connections
Old Jan 8, 2003 | 11:16 AM
Nissan-R's Avatar
Amp connections
I currently have a kendwood head unit which only has one set of pre-outputs. I have a 2 channel amp connected to them. The 2 channel amp does have one set of pre-outputs to connect to another amp. I recently acquired a 4 channel amp.
This is my question: The 4 channel amp has inputs for the front and the rear. There is also a mark that says mono. I can only connect one set of patch cables, but I don't know if I connect them to the front or rear inputs or the mono. I know I will loose the fader control, but would like the 4 channels to work.
Can someone point me in the right direction. Thanks.
Old Jan 8, 2003 | 11:40 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Amp connections
Call Kenwood. Actually, all of the 4-shannel amps that I have ever owned have had the option of 4-independent channel inputs or one pair of "master" inputs that sends each (R&L) signal to their designated channels front & rear.
Old Jan 9, 2003 | 10:20 AM
Nissan-R's Avatar
Anyone??
Old Jan 9, 2003 | 12:06 PM
phenryiv1's Avatar
Mod her. Ate her.
Anyone??
Do you have the owner's manual? How about a model number? We can help only if we know more about the amp. Just knowing that is a 4-channel Kenwood amp tells us nothing. They change from year to year. I will be glad to help w/ the right info.
Old Jan 9, 2003 | 12:16 PM
Nissan-R's Avatar
the 4 channel amp is Sony XM-404EQX. It has front and rear inputs. The front and rear right inputs have a mark that says "mono".
I'm sorry if i confused you, but the head unit is a kendwood.
Old Jan 9, 2003 | 12:21 PM
Nissan-R's Avatar
I don't have the manual, for i purchased from some here in the org.
Old Jan 9, 2003 | 01:08 PM
phenryiv1's Avatar
Mod her. Ate her.
Sony's website does not list that as a model for which they have electronic copies of the owner's manual. Call (800) 222-7669 for either another copy of the manual, assistance in hooking it up, or both.
Old Jan 9, 2003 | 02:01 PM
Nissan-R's Avatar
Thanks for your help, I really appreciated. I went ahead and called Sony. The rep was very helpful. He told me to use the front inputs and I should still be able to use the fader controls on the head unit this way. I also went ahead and ordered the manual, which was $5.00 bucks.
Once again, thanks.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
zmcneely13
Sep 26, 2015 02:26 PM
